Home Forums Printing Discussions Roland Printers Roland Pinch Rollers Problem
  • Roland Pinch Rollers Problem
    Posted by Jason Davies on 26 January 2017 at 08:40
    I have posted about this before but I thought it would be useful to re-post to give some feedback. I seem to be going through pinch roller assemblies very quickly, the new ones seem to crack. The engineer who deals with my service contract believe that the plastic is more brittle. I can believe this as I have been through at least 4 full sets in the last six months. We have been very careful with the machine when changing rolls and using kid gloves to open and close the rollers but they still start to break.
    I decided to give Roland a ring, before this the engineer told me that whatever I raise they will deny any issues with the part and say they have not had a ny complaints……. He was right, I called explained the problem, sent some photos of the cracks in the housing and the response I had was that no one has complained so therefore there is no issue.
    So who has had problems? If you have please respond to this post with the model of your machine etc..
    I’m under contract so these are replaced as part of the contract but I don’t really want to swapping these out every month.
    Stafford Cox replied 8 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Stafford Cox
    26 January 2017 at 14:00
    Hi Jason.
    This is a common fault, but not THAT bloody common!! Are you replacing them with genuine Roland ones? I’d say we probably replace one about every 6 months, but we have something like 100 of these machines on cover so I’d say at worst case, one every 5 years or so.
  • Jason Davies
    26 January 2017 at 16:00
    Hi Stafford, had a couple of replies previously to a similar post so more common than we think and yes they were replaced with genuine roland ones. The machines are VP’s so a few years old but meticulously maintained. As soon as I can get to a milling machine I’m going to make a replacement aluminium set.
  • Stafford Cox
    26 January 2017 at 16:07
    Sounds like a god idea. Let us know how you get on.
  • Simon Worrall
    26 January 2017 at 18:54
    Hi Jason
    I had two end roller housings crack on my SP540V.
    Simon
  • Simon Worrall
    26 January 2017 at 20:02
    Hi Jason
    Simon
  • Jason Davies
    26 January 2017 at 20:44
    Thanks Simon, hopefully there will be others posting with a similar problem. I now release the pinch roller lever in slow motion to be as gentle as possible. Both of mine have cracked again but they seem to have compensated the cut most of the time because of this.
    The original assemblies had been on for about 7 years.
    Stafford is there any adjustment in the lever to reduce the pressure on the assemblies if that makes sense?
    Jason
  • Gary Birch
    27 January 2017 at 08:44
    We also had to replace the pinch rollers on our old Sp540 albeit about 3-4 year ago,
  • Dan Osterbery
    2 February 2017 at 00:32
    We have replaced left and right and a couple of middle ones too. 5 years after purchase. Sp540v
  • Stafford Cox
    2 February 2017 at 10:12
    quote Jason Davies:
    Not that I’m aware of I’m afraid. We’ve got an old SP300 I’ll be stripping down to train a new engineer on in the next few weeks so I’ll have a look to see if there’s anything that can be done to the lever assembly while I’m in there. I’ll let you know if I find anything.
    Stafford
