Home Forums Printing Discussions Roland Printers Roland PC60 positioning of print
  • Roland PC60 positioning of print
    Posted by Steve McAdie on 27 June 2006 at 16:17
    Hi, I have recently bought a second-hand PC60. I am having trouble positioning a graphic on the vinyl I have looked over the boards to see if this topic has already been covered and I can’t find it. I use flexi 6.6 on XP and I am using the print function as you would with a desktop printer i.e file > print, then I use the driver to set the options and media size but when I print it seems to have a mind of it’s own as to whereabouts on the vinyl it prints it.No software came with the printer. I would be very grateful if anyone could help me with this problem.
    Thanks for reading
    Steve McAdie replied 19 years, 6 months ago 2 Members · 3 Replies
    27 June 2006 at 16:49
    You need to set the "base point" on the printer itself.
    Do this as follows:
    Once you have loaded your vinyl – move the knife/print head (using the arrow keys on the printer) to the position where you would like printing to begin (the point of the knife pointing at the actual position). Then press the "Base Point" button on the printer to tell it to start there.
    Then print as normal 😀
  • Steve McAdie
    27 June 2006 at 16:54
    Thanks Phil I’ll give it a try now
  • Steve McAdie
    27 June 2006 at 17:49
    Thanks again Phill,
    It works fine now
