Home Forums Printing Discussions Roland Printers Roland modified pump ?
  • Roland modified pump ?
    Posted by Kevin Flowers on 18 September 2007 at 07:18
    is anyone running a Roland printer with the new modified pumps fitted and do they find it a better than the old system when using max inks.
    Running a Sol 2 which i rebuilt earlier this year with new B&P pumps, new heads but feel that it struggles at times to keep the heads clear. Mod kit is approx £200 which isn’t a problem but i’am interested to get anyones views if they are running a modified machine.
    Jason Xuereb replied 18 years, 3 months ago 7 Members · 16 Replies
  • 16 Replies
    18 September 2007 at 08:46
    hi kev
    i was told by roland you have to change all 3 pumps together, i hope that is £200 for the 3 pumps and fitting kit NOT EACH ?.
    i thought of getting a kit in stock so as when the next pump goes fit the lot they are ment to last considerably longer.
  • George Elsmore
    18 September 2007 at 08:57
    Kevin do you find the heads blocking a lot with this mod kit?
  • Kevin Flowers
    18 September 2007 at 08:58
    Hi Chris
    yeah £200 for the kit & 3 pumps. Pumps are £42.50 each, Kit one off purchase of £51.00. You remove pump & stepper motors fit adapter plate & fit new pumps you then adjust machine software to a modified cleaning cycle which the new pumps are designed to stand up to.
  • George Elsmore
    18 September 2007 at 09:18
    So its not worth doing are you saying Kev?
  • Glenn Sharp
    18 September 2007 at 09:47
    my understanding is that the new pumps are a lot more reliable & won’t need replacing in a hurry….which was a bit of a problem with the old ones
  • Kevin Flowers
    18 September 2007 at 10:46
    George
    i’m looking at actually doing it, just curious if anyone is running a machine already using them & their findings since the conversion. The £200 isn’t the problem a few printed meters & its paid for but don’t see the point of changing if there isn’t an improvement. As an ex engineer i’ve seen modifications implemented on machines that have been a complete waste of time & created more faults than they solved just trying to avoid going down that road. I’ll may be try them & post my findings
  • George Elsmore
    18 September 2007 at 10:50
    Cheers Kevin was mulling it over myself, the reason i say that is a girl i know with another company i help out had problems with the light ink heads blocking ie light magenta and i think it was her light cyan which makes me wary about this
    18 September 2007 at 11:41
    as i understand it it the pumps off the new VP range, so are there any problems with them ?
  • Kevin Flowers
    18 September 2007 at 13:13
    George
    sometimes the problem with lc & lm clogging is due to some profiles actually not using the lc & lm colors although the profile says that its a 6 color profile. Seems to be common on low quality settings etc but have seen it on standard profiles. So the heads clogg whilst running back & fourth over the heated vinyl. If there is going to be any problems then i would expect to see it across the entire set of heads.
  • Ian Bingham
    18 September 2007 at 15:23
    Had new pump fitted on mine, bit louder, Clic clic clic, but works great
  • Glenn Sharp
    18 September 2007 at 15:25
    our new pumps are much quieter than the old clicky ones…..strange
  • Ian Bingham
    18 September 2007 at 15:31
    May be its just me, but is the new pump, as they are fitted as standard on all services
  • Glenn Sharp
    18 September 2007 at 15:34
    With the old pumps you could hear if one of them wasn’t working….not going to be so easy to tell now 🙂
  • Kevin Flowers
    18 September 2007 at 16:06
    Well just ordered the 3 pumps & kit will let you know what i think when its all up & running
  • Stephen Morriss
    18 September 2007 at 16:15
    I’ve been told that the new pump is much stronger and is more like using the syringe, they also last a lot longer, having said that my old pump is still going ok on my Cadet (converted SP750)
    Now I’ve said that it’ll break 🙂
  • Jason Xuereb
    19 September 2007 at 08:46
    Mine have been changed as well and click click click now.
