Home Forums Vinyl Cutter Discussions Roland Cutters Roland GX24 Cutter
  • Roland GX24 Cutter
    Posted by Darren Lawlor on 4 November 2009 at 13:53
    Hi Folks,
    WE have a Roland GX24 cutter that we use for Small jobs. It came with software called Sign Studio which is very basic. We have this kind of set up as a stand alone machine with its own pc etc. The problem is that it has a very limited amount of Fonts. Is there any way that I can add fonts to the already installed ones. I have searched on the pc for a folder titled FONTS and that associated to this software but am having no joy.
    Regards,
    Darren.
    Gary Birch replied 16 years, 1 month ago 4 Members · 4 Replies
  • Neil Speirs
    4 November 2009 at 13:58
    Do you not have any other software like coreldraw that you can cut from?
  • Paul Humble
    4 November 2009 at 14:08
    Doesnt it just use the fonts from your PC?
  • Darren Lawlor
    4 November 2009 at 14:29
    Hi Guys,
    I do have signlab attached to other machines but the CutStudio software and Roland Gx24 was just a stand alone setup away from the larger and more expensive equip. It s used regularly for small signage, and grment printing.
    By the way, you will see that I have renamed the software to CutStudio as opposed to Sign Studio…..I just copped my earlier mistake as it is in fact called CutStudio.
    I am unsure if it just uses the fonts on my pc and if so what program is it drawing them from. I don’t have any software on my pc with such a small selection of fonts available.
  • Gary Birch
    4 November 2009 at 14:39
    Forgive me if I am stating the obvious but why not install a new font on your pc and then see if it works it the software. I would have thought it should.
    Gary
