Home Forums Sign Making Discussions Gallery Rod Ward Site Board
    26 September 2002 at 19:04
    very smart tim!
    i like the script “and sons”
    the whole thing works well… what are you going to print the bricks and trowel with?
    i would maybe make the “&” symbol in light green like the “contact”
    breaks the phone numbers apart…
    lovely sign none the less 😉
  • eddie cotter
    26 September 2002 at 19:56
    lovely design work, great colours, well done tim!!!eddie
    26 September 2002 at 22:48
    Nice one Tim, what sort of size is it ?
    Will you just print it all for speed ? what are you going to mount it on ?
    So many questions !!!!!
  • Tim Shaw
    27 September 2002 at 08:57
    It will be 3′ wide all cut vinyl. We will be printing the bricks and trowel on a gerber edge.
    Mounting on 8mm Foamex or piece of dibond if we have a piece kicking about, its that be more durable than Foamex, especially if its going to thrown around a builders van.
    28 September 2002 at 00:53
    Tim I realise that you are doing this as a favour for a mate, but if you had been asked to do this for a paying customer what sort of money would you have charged ?
    just curious !!
  • Tim Shaw
    30 September 2002 at 17:50
    Martin, i probably would’nt have produced a design such as this without making sure I had some idea of customer budget.
    Off the top of my head when I have to give price, my rule of thumb for a job about this size is £12.
    1m x £12 x no off colours + 1 ( for board if foamex)
    therefore 1 x £12 x 5= £60 plus labour 1.5 hours total £82.50
    if the board size had been 2000m
    price = 2 x £12 x 5 + labour = £145.
    Hope this makes sense.
    30 September 2002 at 18:37
    You’ve lost me completely (?)
    Lovely sign though 😀
    30 September 2002 at 19:28
    me too 😕
  • Tim Shaw
    30 September 2002 at 20:32
    Sorry guys, let me try again.
    The panel size is 1m x .8m.
    I then times the longest measurement by £12. (1m x £12)
    I then times this figure by the number of colours of vinyl used in the sign, in this case 4 ( 2 greens, black and white)
    Add 1 for the foamex panel giving a total of 5.
    5x £12 plus any labour cost gives the total sign panel price.
    Works very quickly in practice.
    There, I hope it makes senses this time.
    30 September 2002 at 20:39
    ah i understand tim.. 😀
    surely you dont pay the same for foamex as you do vinyl though 😕
  • Tim Shaw
    30 September 2002 at 20:47
    We get a sheet of 5mm for £25, 8’x4′ Foamalux
    £50 if you double up. Therefore a third of a sheet is charged at £17, cost price is £8.
    30 September 2002 at 21:01
    ok tim no worries mate.. i was just wondering because you said..
    quote :
    but you charged £12 for the foamex.. i guess at the end of the day. if you are happy with what you charge then thats the main thing 😉
    30 September 2002 at 22:11
    Does that mean you would charge the same for a sign 1m x 1m as a sign 1m x 500mm (both with the same no. of colours)?
    Surely this method throws up a number of inconsistencies? (Rob – can we get a spell check please)
    How did you arrive at this method for pricing work?
    I hope you don’t mind my asking – I think it’s an interesting subject – and I am very interested to hear how others go about pricing their work 😀
    (I use a spreadsheet to price mine – this is very quick and easy – but doesn’t take into account very well the degree of difficulty in making a sign. I don’t think there’s a perfect way to price signs, many methods are very cumbersome – so any method that’s quick and easy has it’s own advantages). Maybe we should open a forum on pricing work?
  • Tim Shaw
    1 October 2002 at 10:11
    i know what you are saying Martin, I have been looking at this problem myself for quite a long time.
    Like I said this method is so I can give a price quickly, If I was making
    10 or so the same, then I would look at the prices a lot closer.
    These prices are an example remember. As Rob says I would only charge
    £12 for the board which cost £8 but the small amout of light green on the job offsets the costs a little.
    I have tried using a spreadsheet before but this as its own problems.
    Square area charging works to a point, but what do you do when the panel size goes over the half way mark on an 8×4 sheet. Say the sign is 2’6″ x 4’6″ ( 11.25 sq feet with 20.75 sg ft wasted) !!!!!
    Do you charge per sq/foot now or do you charge for the full sheet.
    If I charge by the running metre on the longest side, I am including waste.
    If the sign is very complex just increase the £12 figure accordingly.
    You use a spreadsheet , what would you be charging ?
    Do you charge for
    1 October 2002 at 11:19
    For a sign 1000mm x 800mm x 5mm PVC sign – 4 colours and an area printed (say 250mm x 250mm thermal transfer print). I would have priced this at 97 pounds + VAT.
    I might also add on a precentage increase to this figure as it’s a very good design – and quite a complex sign to put together.
    I usually disregard materials wasted as these offcuts always get used eventually for something.
