Home Forums Sign Making Discussions General Sign Topics Roadside Signage Fixings – Supplier?
  • Roadside Signage Fixings – Supplier?
    Posted by Pryam Carter on 17 August 2005 at 19:38
    As far as i can make out there are two ways to fix a sign to a post by using a rail.
    One is with clips which tightens with the aid of a bolt, this tightens and pulls the sign up against the post. This l’m familiar with.
    The other one l’m not. From ones i’ve seen about it looks like a metal strip that wraps around the post until tight and is then snapped of, a bit like a cable tie.
    Does anyone know of a supplier who can help me?
    Stephen Ingham replied 20 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
    17 August 2005 at 19:42
    d. gibsons in rutherglen glasgow. cheapest i have found.
    you need the full setup… banding machine, banding strip and brackets.
    its a tricky thing to use, very footery :lol1:
  • Robert Berwick
    You could speak to Keith or Dawn (on hols at the moment) at S&J Signs. I’m sure they’ll be able to help.
    Tel: 0121 264 010
    There will be many others to try, lots have been posted on the boards before.
    Robert
  • Stephen Ingham
    17 August 2005 at 19:57
    Hi, we use screw banding
    this is very similar to the stuff you mentioned except its like a jubilee clip on a roll, supplied with the screw piece and a clip that goes onto the sign track.
    We get ours from a local iron mongary supplier, but i think ashby do them
    stephen
    17 August 2005 at 19:59
    good shout mate… to be honest i haven’t used it, but seen it many times.
    i don’t know how each would compare but i would think the screw type would be easiest, possibly cheaper too…
  • Stephen Ingham
    17 August 2005 at 20:16
    no special tools required; except a screw driver and some tin snips
    we buy it on a 50 metre roll, can’t recall costs but i’ll have a look on friday, if thats not too late, when i’m back in the office.
    stephen
  • Chris Dowd
    17 August 2005 at 21:32
    We use:
    http://www.jcshi-torque.co.uk/tamtorq.htm
    Best stainless steel banding we have came across, and highly recommend, no need for a banding tool, just need a special shaped drill bit (or the tamtorque driver) and away you go.
    The beauty of this is that if you don’t have the bit, you won’t get it off!
    Even our local Council buy these from us now.
  • Pryam Carter
    18 August 2005 at 08:12
    Thanks everyone, as usual very helpful.
    I feared that i’d have to buy some sort of kit as you sid Rob but Signsols link looks pretty good. I’ll check the other stuff out too.
  • Pryam Carter
    31 August 2005 at 12:34
    Stephen………
    Have you got that number handy?
    Pryam
  • Stephen Ingham
    4 September 2005 at 14:42
    sorry pryam, been away last week
    i’ll get it monday when i get in to work
    saying that ashbys sell it i’m sure
    http://www.ashbytrade.co.uk/clip2.htm
    stephen
