Home Forums Printing Discussions Sublimation Printing Ricoh gx3300N Sublimation Printer
  • Ricoh gx3300N Sublimation Printer
    Posted by Billy Lawton on 9 January 2012 at 20:07
    Hi guys & gals,
    I’ve just bought a Ricoh 3300Ndye sub printer, and I’m running it off a Mac on O SX Lion 10.7.2 – it works fine connected direct to the Mac via a USB cable, but I really want to run it on my Ethernet network.
    When I connect it via the hub with a Cat5 cable the Mac doesn’t see it. I think it might be something to do with network settings / IP address (which I have off the printer control panel). The reason I want to do this is I need the printer in another room (with my other printers that are connected with cat5 Ethernet)
    Anyone have any ideas / method please.
    I would be very very grateful
    Billy
    Ian Pople replied 13 years, 11 months ago 2 Members · 3 Replies
  • Ian Pople
    9 January 2012 at 22:35
    set the network address on the printer to a static address in the range you are using. then set the subnet mask to the same one your network is on.
    example
    network 192.168.1.111
    sub 255.255.255.0
    then add a network printer and in the search box the printer should be listed.
    Ian
  • Billy Lawton
    9 January 2012 at 22:55
    Thank you Ian – I will try that in the morning!
    Brill!
  • Ian Pople
    9 January 2012 at 23:19
    open the command prompt
    type ipconfig
    and that will tell you the network range and subnet mask you are in just pick a high number for the last number of the address.
    Ian
