Home Forums Printing Discussions Roland Printers Replacing dampers or vs-640i
  • Replacing dampers or vs-640i
    Posted by Daniel Evans on 9 April 2016 at 16:35
    Hey guys
    How do I go about replacing the dampers?
    Do i need to clamp the hoses, if so what with?
    Also I’ve got an issue with white not coming through, there seems to be a lot of gaps in the tube, is there anything i can do to pull it through?
    PETER SUNG replied 9 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
    10 April 2016 at 08:39
    Daniel by the questions you asked please don’t attempt with out the manual a lot more can go wrong than with the older head system
    There’s a special sequence for air removal
    Why do you want to change them
  • Daniel Evans
    10 April 2016 at 11:32
    Made a complete hash, could do with speaking with you if you’re around.
    10 April 2016 at 18:48
    Not a member so can’t pm
    Google mrsticker I am at work now till 9.30 ish
  • Stafford Cox
    12 April 2016 at 14:39
    Hi Daniel, I only just saw this post. It was nice meeting you today, sorry I was the bearer of bad news. Let me know if I can help in any way.
    Stafford
  • PETER SUNG
    7 May 2016 at 02:18
    I have metallic ink not coming through at all at the moment, Roland only told me 2 years after i got my printer that i should be shaking the cartridges weekly, i’m not majorly phased by it as 99% of my work is not metallic at the moment, but it would be good to get it firing properly again, is it done and dusted? or can it be fixed?.
  • Stafford Cox
    7 May 2016 at 08:34
    Sorry to say it but it’s likely to be the head that needs replacing. I would replace the damper before committing to an expensive new head but I would prefer yourself for the worst.
    Stafford.
  • PETER SUNG
    21 May 2016 at 03:47
    i did a test print of Metallic, a large block today, and it seemed to fire again, except for some minor streaking in it, can that be fixed?
  • PETER SUNG
    21 May 2016 at 04:21
    Heres an attached preview of the test print (solid Metallic)
