Home Forums Printing Discussions Mimaki Printers Replace Pre Fill-Up carts with Cleaning carts?
  • Replace Pre Fill-Up carts with Cleaning carts?
    Posted by Fabrice Menard on 29 July 2010 at 10:00
    Hi all,
    I own a Mimaki CJV30 printer/cutter with SS21 inks (mild solvant)
    My cleaning fluid cart is going to be empty and needs replacement. I heard that this one could be replaced by the pre fill up carts that I had when the machine was delivered in the workshop.
    Did you also hear this? Can I do that without any problem?
    It will just be a way to use the pre fill carts instead of catching the dust… 😀 (I have 8 of them)
    I guess the question also applies to JV33 and JV5 printers as the print mechanism is the same.
    Thanks in advance for your comments 😉
    Brett Bell replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jamie Wood
    29 July 2010 at 11:09
    We were told this too, when our JV33 was installed. Still on the original cleaning cart
    though, so I haven’t tried it yet.
  • Brett Bell
    6 August 2010 at 10:56
    We used up a couple of our prefill up carts with our JV33 with Eco-HS1 inks. Then kept using the genuine washing carts and kept the two left over prefills in case of emergency i.e. running out of washing because I had forgotten to order a spare for the shelf after using the last one 🙄
    They don’t seem as good as the washing carts but they do get you out of the crapper if you need it.
