Home Forums Vinyl Cutter Discussions Roland Cutters Reinstalled versaworks and cut contour not working? Help?
  • Reinstalled versaworks and cut contour not working? Help?
    Posted by Dan Osterbery on 18 June 2015 at 11:47
    Hi All,
    we have two computers that feed our printer both with versaworks. We have had to rebuild one of the computers and we have reinstalled versaworks. On the computer that was not rebuilt, i can make a cut contour, and versaworks reads the cut contour, but if i place the same file in the other versaworks it does not see the cut contour? What am i missing? Ive done a search but all that comes up is people struggling with transparencies and the cut contour. Any help appreciated.
    thanks
    Dan
    Justin Wilson replied 10 years ago 8 Members · 17 Replies
  • 17 Replies
    18 June 2015 at 11:54
    Don’t know is it’s the same with versaworks, but with wasatch you have to have the process cutting paths box checked before you open the file otherwise it doesn’t see the cut path
  • Dan Osterbery
    18 June 2015 at 12:05
    thanks Phil, will have a dig about and see if i can notice any differences between the two versaworks!
    Dan
  • Gary Birch
    18 June 2015 at 12:07
    If you go into the profile in media explorer there is a box which needs to be ticked which says allow cutting or something similar. Pretty sure that will solve it for you.
    Gary
  • Dan Osterbery
    18 June 2015 at 12:14
    HI Guys,
    i have gone to media explorer, and hit the second button, media characteristics settings, then onto, cut controls, where there is a greyed out arrow, which is ticked which says enable cutting? Is this what you are referring too? Hope all is well Gary?
    Dan
  • Gary Birch
    18 June 2015 at 12:33
    Hi Dan
    Yes that is the one. 😕 Not sure then.
    Things are very good here, How is life in the sun?
    Gary
  • Dan Osterbery
    18 June 2015 at 12:38
    AArrrghh might have to ring roland then! All good thanks apart from the fact this week we have had to rebuild a computer and buy a new plotter! But generally busy and no complaints!!!
    Dan
  • Shawn Bentley
    18 June 2015 at 23:03
    hi dan, you say u have re built your computer if so have you re installed the roland swatch cut contour colour (mines like a pink colour) into your program i.e. illustrator etc. as it will need this to cut (I’m sure u know that) just a thought or process of illumination. hope this helps.
  • Dan Osterbery
    19 June 2015 at 07:05
    Hi Shawn,
    unfortunately cut contour is installed and works on our other versaworks on 2nd computer! Strange one this! Cant seem to nail the problem. Roland Uk will no longer help us as they only support UK and Ireland now, so going to enter the fun that is roland spain today!
    thanks
    Dan
  • Shawn Bentley
    19 June 2015 at 13:11
    hi dan does seem a strange one, you know it will end up being something really simple but impossible to find as we have all had at sometime or another. good luck finding sorry couldn’t help further.
  • Stephen Morriss
    23 June 2015 at 08:24
    Did you install Versaworks as Admin?
    I’ve had fun with Versaworks on windows 8 64bit and eventually right clicked the link and made it run as admin. But there was a later version that cured the problem on install only I was to lazy to un-install then reinstall the later version.
    Try asking on the Roland forum.
  • Stephen Morriss
    28 July 2015 at 15:33
    Did you ever sort this Dan?
  • Dan Osterbery
    28 July 2015 at 15:42
    Not as yet Steve, too busy to fiddle about, we have it installed on two computers, so i am putting everything through on the one that works, and when our season ends next month will have some time to wrestle with it, and hopefully get it sorted. Will post what we did when i get it solved!
    Dan
  • Kevin Flowers
    28 July 2015 at 21:44
    Dan
    check the EPS value can’t remember off the top of my head what screen its on but is a normally a problem on re install,
  • Steff Davison
    29 July 2015 at 07:39
    Open up Versaworks from edit menu, queue A properties, file format then adjust EPS margin to 2.00mm. I had the same problem on my install.
    More information is available on the Roland forum under Versaworks.
    Steff
  • Stephen Morriss
    29 July 2015 at 08:12
    I remember that one now, this getting older lark does things to you 😉
    I set mine to 1mm for this reason.
  • Dan Osterbery
    29 July 2015 at 08:23
    Hi guys,
    thanks for your help! have tried 1mm and 2mm but still no luck! Have also tried ticking the special colour boxes and nothing! Could anyone send me a link to the roland forum please.
    Dan
  • Justin Wilson
    11 December 2015 at 20:47
    Phew! Glad I found this post. Dan your problem is very similar to mine.
    Running VersaWorks fine on one system then bought a new system and cannot get VW to recognize cut contours. I could create EPS files on new system, import to old system and VW would recognize the cut lines so I knew it wasn’t my EPS files. Even tried the opposite, bringing EPS files from the old sys to the new syst that I had already print and cut….no luck.
    I followed Stephen’s advice and ran VW as admin and bang…cut lines are there! Thanks Stephen.
    I’ll try to reinstall VW as admin when I’ve recovered from uninstalling and reinstalling 3-4 times in the last day. Until then I’ve set the VW shortcut to always run as admin (Always Run as an Administrator)
    Wouldn’t have solved the problem without this post…thanks everyone! :praise1:
    -Justin
    OS: Win 7 64 Pro
    VersaWorks version: 5.3.0
    Illustrator: CS5 (15.1.0)
