Home Forums Sign Making Discussions Vinyl Reflective recommendation
  • Reflective recommendation
    Posted by Jon Marshall on 24 September 2008 at 11:58
    Can anyone recommend a workable reflective vinyl. I’ve been using Hexis and mactacs range which are about £11 per metre at 610 but both of these are difficult to fit. I’d like something that doesn’t tear like tissue paper (mactac) or stick immediately leaving behind bits of vinyl when repositioning (hexis)
    Jon Marshall replied 17 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
    24 September 2008 at 19:15
    most reflectives are much the same, you can make them better to apply though by laminating them onto normal vinyl first,
    I always wonder why reflectives need such an aggressive glue, and one that de-laminates if you try to re-position the film.
    The daybright from hexis is more forgiving, but costs several arms and legs 😉
    Btw you should be able to get engineering grade for about half what you are paying.
  • John Childs
    24 September 2008 at 21:33
    We like the 5R series from Allprint Supplies.
    More flexible and forgiving than most others.
  • Jon Marshall
    24 September 2008 at 23:37
    Yeah, I’m getting a sample of it so I’ll see how it is.
    Had a bit of 3M Scotchcal the other week which has the controltac adhesive on it and seemed really good. But then it should be at £25 a meter for 610mm!!
    24 September 2008 at 23:46
    3M Scotchcal is all I’ll use.
    Sure it costs more, but it is so much easier to work with.
    It’s worth it, in my opinion.
  • Dave Tickner
    25 September 2008 at 09:54
    I use reflective from Vinyl Logistics, its very user friendly and they also have an offer on this month on the economy, class 1 and class 2 30% off list price! you can even print on it!
    25 September 2008 at 10:35
    quote John Childs:
    JonM,
    i normally use nikkalite from europoint, i use quite a fair amount of reflective, and while i feel nikkalite is probably the best of what i would consider to be the budget reflectives, it still has some of the problems inherrent with other reflective films.
    Hugh
  • John Childs
    25 September 2008 at 13:02
    quote Hugh Potter:
    John,
    is that what the black was i had from you? superb stuff!
    :yes1:
  • Jon Marshall
    25 September 2008 at 14:21
    Well the 5R is a few quid cheaper than Hexis anyway so I’ll probably give it a go.
