Home Forums Printing Discussions Sublimation Printing Quilted Hi-Viz pressing
  • Quilted Hi-Viz pressing
    Posted by Jeremy Howes on 8 February 2008 at 09:37
    Hello,
    Would someone explain any pitfalls and offer suggestions for successful pressing of the quilted Hi-Viz Bomber style jackets?……….. I will be using Poli-Flex.
    Many thanks in advance
    Jeremy
    Steve Underhill replied 17 years, 10 months ago 4 Members · 4 Replies
  • graffica
    8 February 2008 at 15:29
    Hi Jeremy.
    I´ve never done quilted HiVis jackets, but have done loads of body-warmers which I presume are similar.
    Because of the quilting, registration is a problem if you have more than 1 colour.
    Always apply to an area on the jacket that is smooth, with no seams.
    Also when pressing, avoid applying the vinyl to areas which would crease badly. Probably best to smooth out the jacket first and press before application.
    Hope this helps. Chris
    8 February 2008 at 16:30
    dont know if right or not, but i put a press pillow under the area to be pressed,
    that made that area stand proud and just a little over med pressure.
    all was fine done about 6 todate.
    target premium.
  • Ian Bingham
    8 February 2008 at 17:40
    No problems, Do loads of then Yoko from BTC press great, did have some years ago where the die came of the quilt, but not had that problem for a few years, they all print great
    Ian
  • Steve Underhill
    9 February 2008 at 00:23
    I dye sub mine,
    but a word of warning even though youre using flex.
    Dont press for too long, depending on the pressure and heat, it can make the black inside lining and stitching show through.
    The first one we did had the quilted pattern show through the back, but as I say, it was a dye sub so 30 degrees or so more, and was 50 seconds in the press.
    so you should be fine, we do them for 35 seconds now and its all ok at 190.
