Home Forums Sign Making Discussions Vinyl Query on underwater matt vinyl! Help please?
  • Query on underwater matt vinyl! Help please?
    Posted by Tim Cowlishaw on 29 October 2014 at 21:14
    is there a matt vinyl that would withstand being on swimming pool tiles under the water
    Martin Pearson replied 11 years ago 4 Members · 4 Replies
  • Cat Wood
    30 October 2014 at 11:57
    Hiya Tim,
    There’s a Metamark MD5 printable matt white vinyl which can be used for underwater applications. It hasn’t been tested (as far as I’m aware) in swimming pools so there would be no guarantee how long the print would last in the chemicals used and the surface it’s being applied to would need to be a flat smooth surface for the adhesive to adhere properly. Test would probably be advised initially.
    There is this guide of how to apply under water.
    http://www.metamark.co.uk/pages_tec/sv_app_water.htm
    Let me know if you need any other info. Happy to help! πŸ™‚
    30 October 2014 at 16:08
    For Health and Safety – always ensure you are wearing the correct equipment when fitting this vinyl
    πŸ˜•
  • Gert du Preez
    31 October 2014 at 11:06
    Why matt vinyl? Surely it will look the same as gloss if applied under water?
    31 October 2014 at 14:14
    Probably best to speak with suppliers about this one Tim, cast is generally OK for use on boats & in sea water but the chemicals that are added to swimming pools may have an adverse effect on some of the adhesives used with different brands.
    Does it really need to be a matt vinyl? As Gurt says under the water a gloss might not look much different, test a small sample of each to see.
    Phill forgot to mention that as well as all the correct gear you will also need someone suitably qualified to act as a safety number while your fitting.
