Quantas Airlines
After every flight Quantas Airline pilots fill out a form called a gripe sheet which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight. Never let it be said that ground crews and engineers lack a sense of humour. Here are some actual logged maintenance complaints and problems as submitted by Quantas pilots and the solution as recorded by Quantas maintenance engineers.
By the way Quantas is the only major airline that has never had an accident.
(P= The problem logged by the pilot.)
(S= the solution and action taken by the engineers.)
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Test flight OK except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Auto pilot in altitude-hold mode produces 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear
S: Evidence removed
P: DE volume unbelievably loud
S: DE set to more believably level
P: Friction locks because throttle levers to stick
S: That’s what they’re there for.
P: IF inoperative
S: IF always inoperative in off mode.
P: Suspected crack in windshield
S: Suspect you’re right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right , and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
