• QR codes help
    Posted by Mike Grant on 15 February 2012 at 21:16
    I have a job to do that includes a QR code "pattern" I had a copy given to me but it was of a low resolution. 🙄 I tried countless times to trace it in Corel but could only get a rough finish. I ended up drawing it from scratch which took a fair bit of time that I hadn’t accounted for. So my question is this, how are these bar codes made and what is the easiest way of reproducing these as a vector and is there a limitation on the reproduced size of the finished code.
    Neil Fox replied 13 years, 10 months ago 9 Members · 11 Replies
  • 11 Replies
  • Andrew Blackett
    15 February 2012 at 21:20
    Hi Mike,
    I used http://qrcode.kaywa.com/ on a recent job (on the laser engraver) It’ll download as a png graphic but they trace beautifully in corel.
    I think I got these down to about 15mm square on the tags – don’t think theres a maximum size, as long as the lens on the reading device can fit it in.
    Andy
    15 February 2012 at 21:43
    just done a few from my android phone using QRdroid its a bit map but all square and straight lines. so enlarged well.
    when i find my phone i will trace one to see what happens.
  • Andrew Blackett
    15 February 2012 at 21:46
    Just found this one which negates the tracing step;
    http://qrcode.littleidiot.be/
    It will let you download the finished code as pdf, eps and others
    Andy
    15 February 2012 at 22:01
    thanks andy
  • Denise Goodfellow
    15 February 2012 at 22:28
    I don`t know if this is true. but today I heard that they can be used to make your phone dial a high rate number (scam)
  • John Gregson
    15 February 2012 at 23:40
    quote :
    They can be made to direct you to anything really, normally websites etc.
  • Tobias Redig
    16 February 2012 at 07:03
  • Chris Windebank
    16 February 2012 at 09:13
    this one for me, nice crisp EPS
    http://delivr.com/qr-code-generator
  • Richard.Peirce
    16 February 2012 at 10:52
    One thing to consider when creating these QR codes is to track if they are actually being used, otherwise it could be a waste of time and until all mobile devices have an automatic QR scanner in them, people have to download a QR scanner to even read them!
    With this in mind, one everyone could probably use, Google Analytics! Use the below link to create a link, set it up as a QR monitor relating to your campaign/advertising and monitor to see how much its used. Once you have the link, use a QR generator to get your QR code, and you can monitor its use!
    http://support.google.com/googleanalyti … swer=55578
    Then use the link in something like the one Andy posted: http://qrcode.littleidiot.be/
  • Mike Grant
    16 February 2012 at 17:22
    Thanks for all your help guys. 😀
    I shall check out all the links when I have a chance.
  • Neil Fox
    24 February 2012 at 09:36
    I have done a few QR codes. Many of them are created as png or jpg images.
    I have just proportionately expanded them in Flexi or Illustrator from the png or jpg. As they are perfectly square (black & white), they expand with no pixilation.
    The largest one I have printed has been an 8ft x 8ft one. It was enlarged from a jpg file supplied by the customer.
