Home Forums Printing Discussions Roland Printers Processing error problem
  • Processing error problem
    Posted by Mike Grant on 1 July 2010 at 20:37
    I have been trying to send a print/laminate/cut job down to the printer.
    When I rip it, at exactly 5 mins and 23 seconds it keeps giving me this message…."ps3 MFC application has encountered a problem and needs to close"
    I have tried this six times and each time it does the same. Can anyone tell me what this problem may be.
    SP300 machine. Job length is 3.5 meters long x 650mm. Job is saved at 25% of full size.
    Jamie Wood replied 15 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tim Painter
    1 July 2010 at 21:50
    What file type Mike?
    What elements does it consist of?
  • Mike Grant
    1 July 2010 at 22:14
    quote Tim Painter:
    EPS
    quote Tim Painter:
    Its a Corel file of graphic stripes that has a Photopaint "plastic" filter on it.
  • Mike Grant
    1 July 2010 at 22:17
    I printed a test sample at 700mm long with no problem. But when I enlarge it, it hangs up???? I have cleared all my job queues, and deleted a load of files in case it was a memory problem.
    Sounds familiar – have you seen this Mike?
    http://www.uksignboards.com/viewtopic.php?t=42978
  • Mike Grant
    1 July 2010 at 22:55
    Phil, nothing has been tampered with or upgraded. Why does it print the small one but not when I enlarge it. (?) (?) (?) 😥 😕
    2 July 2010 at 20:24
    is it a older ver of colourrip
  • John Hughes
    2 July 2010 at 20:47
    Try – go back in to corel and save job as PDF and RIP that – still 25%
    john
  • Jamie Wood
    3 July 2010 at 00:18
    You could also try saving the enlarged file as a high res JPG, with the same profiles from your
    design package. This should keep your colour accurate. I often do this if I’m having problems with
    a file ripping, and then I just use the original file with any layers as the cut file. Just make sure that
    any print marks that may be needed for your cutter are included in the JPG.
