Home Forums Printing Discussions General Printing Topics Problems with printing
  • Problems with printing
    Posted by Neil Kelly on 15 April 2011 at 16:16
    Hi i was wondering if anyone has come across this problem and what the fix might be its only started to happen recently we print on a mimaki cjv30-130 and we are getting these random dark lines they seem to be on the peaks of the raised vinyl as it come through the printer normally at the beginning of the run before the take up rollers start to pull. is this a commen fault or can it be avoided.
    any tips would be appreciated.
    Thanks Ned 🙂
    Dermot Howard replied 14 years, 6 months ago 4 Members · 5 Replies
    15 April 2011 at 16:21
    you might be overcooking the vinyl
    the uneveness is due to quick change from cold to hot and if too hot it will cause the vinyl to lift
    drop the temp
    dave
  • Neil Kelly
    15 April 2011 at 16:32
    Thanks that make a lot of sense what temp should we be set at…
  • Andrew Fleming
    16 April 2011 at 14:47
    Neil
    All vinyls are different, I have the same machine and mainly run md3 and md5 and they are both different temps, try you settings down to 35 35 and 50
    16 April 2011 at 17:57
    only way to find out… test test test
    try knocking it back by 5 degreees first
  • Dermot Howard
    16 April 2011 at 18:09
    I get the very same peoblem from time to time, it is the temp, and I find sometimes a roll that is not rolled tight
