Home Forums Printing Discussions Uniform Printers Problems with colours mixing where they shouldn’t!
  • Problems with colours mixing where they shouldn’t!
    Posted by Gary Thornton on 30 October 2013 at 15:23
    Hi fellow cadeteers.
    I’m looking for some advise please.
    My cadet plus is having a benny which has been getting progressively worse lately.
    I was having a problem with black ink back feeding up the blue ink line.
    Someone recommended levelling off the inks in the reservoir which did cure the problem. But now the red was finding its way into the yellow, although this time the dampers were staying the correct colour.
    I can draw the inks through with a syringe and it will appear to print ok, but within a matter of minutes after printing a test print it shows red in the yellow and blue again in the black.
    Any suggestions would be great.
    I’ve ordered 4x new dampers and capping stations to fit and I stripped the piping the other day under the capping stations right through the pump and cleaned them so they were spotless.
    Is there a non-return valve in the dampers?
    HELP!!! Please 🙂 cheers Gary
    Stafford Cox replied 12 years, 1 month ago 2 Members · 3 Replies
  • Stafford Cox
    18 November 2013 at 05:56
    Hi Gary. Wait until you’ve fitted your new caps and see if it’s doing it.
    Personally I would replace the pump for a new genuine one too. It may have a bit more life in it and it may not be the main problem but with a new pump and cap in place, it will definitely improve the life of you heads, which ARE expensive.
    Stafford
  • Gary Thornton
    19 November 2013 at 10:32
    Hi Stafford.
    Thanks for the reply. It seems to be fine now.
    I’ve just put a new printhead in the black and blue slot too.
    All is well again.
    Do you know if there is a procedure after printing to stop the heads blocking up?
    I’m using an oem black ink but the following day there were a load of misses on the test print???
    I’m sitting the head on cleaning fluid when I’ve done for the day, but its a bit of a pain??
    Answers on a postcard 😉
    Cheers Gary
  • Stafford Cox
    19 November 2013 at 15:13
    They shouldn’t really be blocking up while it’s idle. I could only think that the cap or alignment could be at fault??
