Home Forums Software Discussions General Software Topics problems opening files?
  • problems opening files?
    Posted by Derek Heron on 16 May 2005 at 07:38
    morning all
    having problems opening files in corel draw
    i had some files sent to me on disc eps and ai files when you open the disc you can see a.i symbol for eps files and you can see a thumbnail of the a.i files i can open eps files and cut no problem in corel
    the a.i files will open in a.i but message saying (generated by newer version some data loss may occur)i would normally just save a copy and open in corel when i do this corel will open but with nothing on the page
    have tried all the view options in corel still nothing cant understand it any help appreciated
    Dex
    Nicola McIntosh replied 20 years, 7 months ago 5 Members · 5 Replies
  • Jayne Marsh
    16 May 2005 at 13:43
    Can you email me one of the problem files and I’ll have a look at it for you, I have a few minutes spare ( putting off doing my books till tomorrow ) 😀
    info@jemdesign.fsnet.co.uk
  • Peter Shaw
    16 May 2005 at 19:51
    Try opening as Postscript Interpreted rather than Encapsulated Postscript.
    16 May 2005 at 21:02
    Hi, first off, what version are you using?
    Corel 11 cannot open the latest Illustrator files
    Corel 12 does open Illustrator CS files
    Importing with Postscript Interpreted and Adobe Illustrator AI is the best ways, however the new Adobe Illustrator can use PDF format as a native format. To test, do this:-
    Rename your file from File.ai to File.PDF
    Double click and open in Adobe Acrobat Reader/Pro
    If you see the item and have Acrobat Pro, then save as EPS/Postscript
    Then Import into Corel
  • Derek Heron
    17 May 2005 at 20:15
    thanks all concerned Dave peter and especially jayne
    problem solved money saved onwards and upwards this was one of those problems which i could have kicked around and around for ages my mate who is a right techy was starting to get the hump
    thanks again
    dex
    17 May 2005 at 21:10
    quote DaveRowland:
    good one dave..been using adobe distiller but found it never converted to eps everytime…will give it a go 😛 especially importing to corel 😀 i always tried to import to signlab without much success 😉
    brill another great bit of info 😉
    Nik
