Prints buckling in laminator
Hi All,
Hoping someone may have solved this as it’s a new issue for us after some 6 years of using our laminator.
We have GMP Excelam cold laminator. For the most part it’s been trouble free but what we have now is a situation where the vinyl starts out okay going through but as it gets to 3 or 4 metres in, the vinyl appears to start buckling slightly which eventually would ruin a long print. If you’re lucky, the job will get through before the point of ruin. Any left over vinyl fed in to the printer from the front then looks visibly wavy where it would normally be flat on the platen.
What is mystifying about this is that nothing has really changed on the laminator. Earlier in the year we could laminate 5 or ten metre rolls without a problem. Changing the vinyl and laminate doesn’t seem to have made a difference either. The vinyl is clearly flat on the roll before we start laminating it.
The only thing that has changed is the weather – it’s very humid right now, but surely everyone would be getting this if it was down to that?
