Home Forums Printing Discussions Roland Printers Printing white on a versacamm
  • Printing white on a versacamm
    Posted by Nick Tunstill on 3 August 2013 at 08:28
    Hello
    I need to reverse print on clear and apply white to the back for some window stickers. The issue I have is my customer wants 1000’s of small stickers.
    Looking at all my profiles for clear with white, it’s going to take 2 hours to do 1500mm x 760mm. Way too slow. Does anyone have a suggestion for producing these quicker? I have a versacamm vs 300 running versawoks 4.1.1
    Many thanks
    Nick
    Gary Birch replied 12 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
    3 August 2013 at 08:32
    i have the same problem at times if a spot area only then print else laminate the back with a white vinyl, then cut
  • Nick Tunstill
    3 August 2013 at 08:39
    Thanks Chris
    It’s an overall white but the trouble is putting a white vinyl will take too much time/material as well so not be cost effective.
    Nick
    3 August 2013 at 08:49
    sorry nick cant see the problem cost of 1 half mts vinyl and ten mins plus makes a easy to handel sticker as the solld white fill make the single vinyl soft.
    and you print normal colours as fast as you like
  • Nick Tunstill
    3 August 2013 at 08:58
    I will give it a try! Many thanks Nick
  • Andrew Blackett
    3 August 2013 at 09:04
    We do as Chris suggested quite a lot – it definitely works and having the white vinyl at the back acts as a "laminate" protecting the print from scratches etc.
    Andy
  • John Thomson
    3 August 2013 at 09:14
    I reverse print on white then laminate and it works well.
    If you are going to contour cut then I suggest putting a small piece of masking tape over the alignment marks before you laminate……then cut them out with a scalpel so that the registration marks can be seen.
    john
  • Nick Tunstill
    5 August 2013 at 13:39
    I tried this and it works well, many thanks.
    Only question I have is, how do you trim it as the marks are on the inside of the paper/white?
    Nick
  • Gary Birch
    5 August 2013 at 14:14
    quote Nick Tunstill:
    Nick
    We cover the registration marks with masking tape before backing off with white. We then use this as a guide to carefully remover the white vinyl which covers the marks with a scalpel. It is very simple when you get used to it.
    Gary
