Home Forums Sign Making Discussions General Sign Topics Printing Rollups – No Lamination
  • Printing Rollups – No Lamination
    Posted by Adam Zeit on 10 June 2011 at 13:29
    Does anyone print rollups without lamination? I have a 100 rollup order and I want to try and print it on a special paper that doesn’t need lamination (syntethic). Which one do you use? Does it look good?
    Mark Latchford replied 14 years, 6 months ago 8 Members · 11 Replies
  • 11 Replies
    10 June 2011 at 13:56
    i dont print onto paper for roll-ups. i use a grey backed polyester film.
    in all the years we have printed roll-ups i have never laminated them and never had a single problem.
    that said, i know many do laminate…
  • KevinGaffney
    10 June 2011 at 16:27
    Same as Robert, we never laminate. Rollups are relatively cheap here and wouldn’t justify laminating. Never had a problem either. Only tip, I always give them a strong 24 hours to fully cure, less chance of damage when fitting into device
  • Adam Zeit
    10 June 2011 at 16:30
    Rob, Kevin, Thanks a lot.
    Do you know how thick is the material (micron?) you use?
    Don’t the edges (sides) of the material roll outside when the rollup is open?
  • Mike Grant
    10 June 2011 at 17:58
    Metamark do a material that has a satin finish that doesn’t need laminating but looks like its laminated. Found this out just after buying a roll from Hexis 🙄 not that I laminate them anyway. 😳
    10 June 2011 at 18:30
    i use layflat banner material.. love it
    10 June 2011 at 19:37
    depends on what the customer wants to pay for, some want lamination and some don’t, I think the finished product looks brilliant with anti-scuff on them, totally protects and gives a nice finish without any finger prints on them 😀
    10 June 2011 at 22:16
    i had this argument at work not long back… i think it is completely daft to laminate a roller banner that is going to spend it’s life mainly curled up, when u unwind it after say storage for weeeks, i think you have more hassle with it.
    I correct myself… its called "SoFlat" banner material… is lovely and really is good in roll up cassettes and curl is slightly there.
  • Adam Zeit
    11 June 2011 at 11:45
    Thanks a lot.
    I’ll definitely buy a roll to try it out. Normaly we use 130gsm paper with 2 side 75 micron lamination for our rollups, however i tend to simplify this process and try the soflat material you’ve all recommended.
    Thanks!
  • Mark Latchford
    12 June 2011 at 14:55
    We use a textured material from Papergraphics which doesn’t need laminating and comes on a 50metre roll instead of the usual 30m called
    SV-TRU220 – grey backed textured roll-up banner film 220mic
    It only csots £125 – 68p per roll of 914mm x 50m. It give a really good finish and you can bareley tell that the finished item isn’t laminated
    12 June 2011 at 15:46
    thanks for that mark, if using ecosolmax inks whats the drying time like please.
  • Mark Latchford
    12 June 2011 at 15:58
    We leave about 1 hour Chris but have finished printing and put in the cassette straight away with no problems
