Home Forums Vinyl Cutter Discussions Roland Cutters Printing onto magnetic media with SP540V versacamm
  • Printing onto magnetic media with SP540V versacamm
    Posted by Carl Maguire on 2 March 2009 at 21:34
    Hi there has anyone ever used any magnetic media in a Roland Versacamm SP540v or does anyone know can you actually print onto magnetic with this machine as I have an idea for a customers racking labels but did not want to suggest it if my machine wont work with magnetic media
    Shane Drew replied 16 years, 9 months ago 6 Members · 6 Replies
  • Kevin Flowers
    2 March 2009 at 21:47
    I have done it once successfully on a Soljet SC545Ex, next time i tried it just messed up. Issues with the Sp540v will probably be motor error due to the weight of the mag also the mag tends to keep a curve as it comes off the roll. If your head strikes it will demolish your head quite easily, i believe there is some thinner digital mags material but not found a supplier in the UK yet.
    2 March 2009 at 21:59
    like kevin done it once, wont make a habit of it. that was .8 mag. all so the cut path calibration is a mile out on this thickness.
    i want to try some thin mag from spandex designed for the edge printer.
    2 March 2009 at 23:30
    Even on the edge printing on mags direct can be a pain,
    just buy uncoated mag material and apply the printed vinyl, I cant see it worth taking the risk to do otherwise.
  • Jason Davies
    2 March 2009 at 23:47
    Agree with Peter on this one, it’s not worth the heartache and disruption, just apply printed graphics to the sheet.
    Jason
  • Fred McLean
    3 March 2009 at 08:18
    Just printed some grafityp mag on our rockhopper,printed fine but had the front heater up too much to start with and it curled and smudged the print a bit,got it printing no problem after sussing out that problem 😀
    Chris, the stuff from spandex is really thin,but we used it a while ago for loads of planning board decals at 20mm square icons for scaffolding and the like for an oil co.and they were spot on.
    3 March 2009 at 08:47
    I use the .2 printable mag on my SC540’s and it does a great job. Die cuts too, with a sharp blade.
    I don’t imagine you’d have any issues with you machine using this product.
    Strictly fridge mags though, not suitable for cars.
