Home Forums Printing Discussions General Printing Topics Printing graduated fills..problem
  • Printing graduated fills..problem
    Posted by Mark Candlin on 1 December 2004 at 11:38
    Hi all, I like to use a lot of graduated fills in my artwork on letter styles they look great but I always seem to get banding problems.
    Iam using corel 11 to produce the artwork and print onto my verssa cam.
    The procedure i use is as follows ,say for a letter “A” 12″ high.
    Scale the letter up to 12″ high add a outline etc and fill with a graduated colour , say black to white. when happy i export as an eps ( the letter also has an cutpath for cutting latter so i asume that an eps is the only format i can use)
    The problem is the graduated tint then becomes a series of “solid” looking bands , they are not to obvious but they are noticeable, is there a way round this.
    Am I right in thinking that it is the eps format which does this?
    Ive tried producing the fill in photoshop importing into correl and exporting out as an eps with cutpath included with the same result.
    Changing the Fountain steps to a high number dosent help either.
    Any Ideas??
    Mike Antrum replied 21 years, 1 month ago 3 Members · 3 Replies
    1 December 2004 at 12:45
    i have auto increase fountain fill on and set to 600 steps may be wrong but works. if i use a transparancy the has to be sent cmyk.
  • Mark Candlin
    1 December 2004 at 16:27
    thanks chris
  • Mike Antrum
    1 December 2004 at 21:30
    Also, what software are you using to drive the VersaCamm?
    If you are using Roland Colorip, check you are using the latest version (2.2). If not, you can download it from http://www.rolanddg.com.
    In addition to this download the new profiles (They have a V2 in brackets at the end of the profile name). Some of the improvements in the RIP and the new profiles were specifically to improve graduations.
    Regards,
    Mike Antrum
