Home Forums Printing Discussions Sublimation Printing Printing Door Mats, sublimation heat settings help needed?
  • Printing Door Mats, sublimation heat settings help needed?
    Posted by Wayne Maxwell on 1 January 2022 at 18:53
    Hi all.. not sure if anyone has come across this before.. or if it can even be done?
    I’m trying to press a floor mat through a rotary calendar press but the ink isn’t taking to the material as I think the time isn’t long enough although I have it on the slowest speed.
    Should I up the temperature and give it another go or am I barking up the wrong tree.
    Wayne Maxwell replied 3 years, 10 months ago 2 Members · 4 Replies
    1 January 2022 at 19:20
    I don’t know anything about doing it via a rotary press, but if it’s sublimation and you have a spare one or you have wasted one, I would try tests and increase the heat. If it is sublimation, are the mats definitely for sublimation printing?
  • Wayne Maxwell
    1 January 2022 at 22:39
    Thanks Robert.. yes I think next step is to ramp up the heat as I can’t make the speed go any slower. I buy these on a smaller scale for jobs so definitely the correct media, I usually press these on a small clam style press but the size of 60cm x 40cm is just to big for the small press 👍
    2 January 2022 at 15:18
    Guessing you may have already tried this Wayne, but is the temperature setting on your clam press machine the same temp as your Rotary Press?
    • Wayne Maxwell
      5 March 2022 at 16:01
      Robert to cut a ling story short we just bought a classic press big enough to press the floor mats.
      Works a treat. Thanks for taking time to reply.
