Home Forums Printing Discussions General Printing Topics Printing a Photo with a Gerber Edge???
  • Printing a Photo with a Gerber Edge???
    Posted by Dave Springate on 17 July 2004 at 22:22
    Just playing aroiund with my new edge printer. Anyone know whats the best way to import a photo into sign lab (size etc) so that i can print it full width of vinyl.
    Gordon Forbes replied 21 years, 5 months ago 5 Members · 10 Replies
  • 10 Replies
  • J. Hulme
    18 July 2004 at 22:34
    Sorry mate, but just as I always have to ask, what size?
    I don’t (anymore) print with signlab, however, convert to CMYK with photoshop, adjust resolution, resize (not needed in flexi, maybe not in signlab) import, resize, rip and print.
    Go for .png(ping) files if poss and you’ll get fabulous results from thermal!
  • Dave Springate
    19 July 2004 at 07:35
    Hi outline,
    I would like to print full width of printhead if possible. Just to see what the result is really, its not a customer job, just me finding my way with the new kit.
  • payads
    19 July 2004 at 08:03
    Iv’e an edge, never worked with signlab though, are you wanting to print bigger than the 298mm width for the the edge, bit confused what your wanting to do…
    Frank
    19 July 2004 at 09:32
    frank, i think signlab 7 is the thermal print version on the go for the edge.
    having said that i did used to run it for our pc60 a while back thats v5 rev12 colourmaster
  • payads
    19 July 2004 at 10:09
    thanks rob
    nice to know signlab 7 is
    Frank
  • Dave Springate
    19 July 2004 at 10:28
    All i want to do is export from Corel photo paint into sign lab and print image with gerber machine. Just wondering what file format is best to export from corel and also what sort of dpi i should be exporting as bearing in mind that the Gerber is max 300dpi. Its just a small test to see what a photo will turn out like. Say a normal 7×4 photo and blow it up to maximum without having to tile it so maximum height for printing will be 299mm
    Hope his is a bit clearer???? 😕
  • payads
    19 July 2004 at 10:51
    import image from coral.
    go to options in omega
    select your image editor (put this as coral or whatever ur using) this will allow you to edit the image in composser and coral.
    u can then import image using file import button etc.
    once u have the image ready to print select all then go to set up in composer : device select, print mode, u can now use 600*300 dpi for clearer prints.
    you can also hit the 123 icon and change the halftones.
    For photos use photowork either, fine or long( fine for veiwing close up, long for veiwing at a distance.
    if you play about with these settings you will be able to change lines per inch etc.
    Happy playing with your new toy….
  • Dave Springate
    19 July 2004 at 11:21
    Hi Payads
    Thanks for that but i dont have Omega only sign lab! any tips?
  • payads
    27 July 2004 at 11:20
    dave
    how did u get on with your photo for edge
    did u get a good quality result
    Frank
  • Gordon Forbes
    28 July 2004 at 11:12
    Thought V6.1 is the one with the thermal output definitley does edge cause you can choose one in the set up.
    Take it in as a jpeg (not the best option png is the best option doesn’t compress and distort the same) or even an eps
    When it comes in a black area will cover it put this to the back select both and select clipping (arrange>clipping) drag to the size you want an then print.
    This is the simplest way for a quick plot just for a test.
    Well I find it easy anyway.
