Home Forums Sign Making Discussions General Sign Topics Printed Security Decals
  • Printed Security Decals
    Posted by Neill Hague on 19 September 2007 at 15:27
    A good customer of ours that makes motorhomes has asked if we can supply security decals that go on the vehicles whilst they are being transported.
    The decals are about 50mm high & 200m long, they are stuck on to the edge of the door (across the gap between the door & the panel), the idea being that if a door is opened the decal would tear, to show that the door has been opened.
    any suggestions for a supplier would be much appreciated
    thanks
    Neill
    Neill Hague replied 18 years, 3 months ago 7 Members · 9 Replies
  • 9 Replies
  • Alan Cooper
    19 September 2007 at 16:03
    Neill,
    How about using standard vinyl and cutting a vertical perforated line in the film half way across. The vinyl would then tear easily if the door was opened.
    Alan
    19 September 2007 at 17:35
    Alan, the problem with doing it that way would be that it might be possible to lift one end of the decal, enter the van and then stick it back down afterwards and nobody would really be able to tell.
    Don’t know who might do them but printed Avery type labels might be OK possibly laminated.
    19 September 2007 at 17:45
    I can only think of the security label stock from spandex, it breaks apart if it is removed, not cheap, but may do the job,
    Another way maybe, try out some paper labels, as they are only a temporary measure I think with the right adhesive would do the trick…
    the labels on packaging are almost impossible to remove without destruction, don’t know about sticking to paint though, give it a try?
    just a thought,
    if its to detect unauthorised entry, during transport, why not lock on loading and give the transporter driver the keys in a sealed envelope? much simpler, and the keys are available if an emergency arises
    Sorry that will do you out of work though
    Peter 😉
  • Nigel Pugh
    19 September 2007 at 20:43
    I would make them for the interior and stretch from nearside to offside window, you would adhere the ends to the inside of the windows, therefore making them visible and tamper proof.
    19 September 2007 at 21:17
    quote Nigel Pugh – Grafityp:
    Tamper proof maybe Nigel, but how would you get out after applying? 😀
  • Nigel Pugh
    20 September 2007 at 08:25
    Simple Peter, you close the door after you have pulled your arm away 😉
    I know what you mean Peter, but trust me, I gave this a lot of thought last night whilst having a drink or two.
  • Russell Spencer
    20 September 2007 at 09:37
    you are never really going to get a 100% solution to this problem, because the whole idea of ‘tamper evident’ labels/vinyl is that they are difficult to remove, the avery vinyl mentioned earlier is a great product for computer seals and such like, but if you ever have to clean one off, good luck to you.
    I think the perforations idea is the best, if someone tries to peel one end up as said it will be obvious, especially if a permanent adhesive vinyl is used because it will distort when peeling off, also at the most, it will leave some adhesive residue that can be cleaned off.
  • Frank Horner
    20 September 2007 at 12:26
    I have a printable chrome coloured vinyl from Spandex which when peeled off says "Void" (I think) in the adhesive, and cannot be re stuck, therefore making it blindingly obvious that entry has happened.
    Frank
  • Neill Hague
    20 September 2007 at 12:57
    many thanks for the replies, I was thinking of a perforted sort of label.
    I have spoken to the customer & he is going to send me a sample decal he has, he can’t remember who made them originally!!
