Home Forums Sign Making Discussions General Sign Topics Printable clock supplier required, sources needed please?
  • Printable clock supplier required, sources needed please?
    Posted by David Hammond on 28 August 2018 at 15:21
    I’m currently trying to prototype a product, a portable sign, which will incorporate a clock.
    Being protable, the clock face would be better being behind a plastic face. I’ve a printed clock on the wall here from an autospares supplier, it’s perfect for the job… but can I find them anywhere. :bangshead:
    Does anyone know of any suppliers, who can supply a wall clock, we can print the face ourselves, either dye sub or digitally.
    Looking for something similar to the attached.
    David Hammond replied 7 years, 4 months ago 8 Members · 10 Replies
  • 10 Replies
  • David Stevenson
    28 August 2018 at 17:02
    I got something similar from argos. Was a basic clock that I dismantled and printed an insert for my sons room. Cheap as chips 🙂
    28 August 2018 at 17:08
    I used to make clocks as a giveaway to some of my customers. Mechanisms are readily available to buy on line and in bulk quantities
    https://www.uksignboards.com/topic17643.html
  • Chris Wilson
    28 August 2018 at 17:36
    Am guessing you have tried magic touch and xpres? Subli supplies may also be a shout.
    28 August 2018 at 18:20
    Cheers for the tips.
    i’ll look at Argos, never thought of that.
    dye sub blanks seem expensive for what they are, and probably ott for what I have in mind.
    I contemplated that method Phil, but as the boards will be transported, the hands will probably get damaged rendering it useless. I could use a digital clock, but think analogue would look better.
    28 August 2018 at 20:45
    Maybe cover the clock face with clear acrylic held in place using Chrome stand off locators?
  • Philip Gibbs
    28 August 2018 at 21:17
    The movements can be bought from cousinsuk.com.
    They have a good selection of movenents. These are the ones I use at my other job are these –
    https://www.cousinsuk.com/product/standard-uts
    When you assemble the clock it is easy to over-tighten the centre nut which can cause it to loose time. It is better to do finger tight and glue the movement to the dial to stop it rotating.
    1 September 2018 at 19:41
    quote Phill Fenton:
    There is probably a list of ways to do this when we put our mind to it. I love the limitless creativity that comes with being in the sign industry. Things many would never think of like "making a clock" as your demo shows Phill.
  • Steff Davison
    2 September 2018 at 08:01
    How many do you want to buy?
    Or trade supplier printing direct onto acrylic, then add a movement.
  • John Thomson
    2 September 2018 at 14:41
    I made this from an IKEA clock a few years back.
    Think from memory it cost me just over a pound.
    2 September 2018 at 16:16
    Will be adhoc, and each individually printed, so not worth getting in bulk.
    Needs to be cheap(ish) and have the hands protected, I’ll look at Ikea/Argos :thumbsup:
