Home Forums Printing Discussions General Printing Topics PRINTABLE BANNER MATERIAL??
  • PRINTABLE BANNER MATERIAL??
    Posted by Stephen Ingham on 25 January 2005 at 22:00
    Hi all, looking for some recommendations for printable pvc type banner material.
    we ahve just bought our versacamm sp300 and have an order for some printed banners, can anyone recommend a favourate??
    We did order some from paper co. but they sent us some type of self adhesive vinyl by mistake.
    stephen
    Pryam Carter replied 20 years, 11 months ago 7 Members · 15 Replies
  • 15 Replies
    25 January 2005 at 22:09
    Oracal here sell a banner material called 440G. It does photo quality prints on a glossy finish. Brilliant. Not sure if it is an oracal product, but I’ll check when I get to work if you like.
    Shane
  • Stephen Ingham
    25 January 2005 at 22:30
    cheers shane
    stephen
    26 January 2005 at 07:06
    Stephen
    It is a VIZION 440gsm High Gloss White Banner product. They have two versions, one for eco sol printers, and one for true solvent printers. Not sure what the difference is as I use the eco sol version on my true solvent printer. Not buy choice, although it is cheaper, but it is what I was sent when I asked them for a good quality banner material at a reasonable price.
    Hope that helps mate. I have printed 2 x 1.2m x 8m and 6 x 1.2m x 2m full colour banners last week and the results were very very good.
    Shane
  • Stephen Ingham
    26 January 2005 at 08:01
    shane, do you apply any type of laminate once printed (liquid or rolled)??
    stephen
  • Ian Higgins
    26 January 2005 at 08:20
    Metamark do a good banner material for printing..
    We churn them out using the cadet.
    Ian
    26 January 2005 at 08:48
    quote ste68blue:
    stephen
    I don’t usually. If their are concerns for a long term life, I do have a liquid laminate I apply and cure under a UV light.
    Not that often tho.
    Shane
  • Signs & Wonders
    26 January 2005 at 17:29
    Grafityp do a printable banner material, Used it with our rockhopper 38. They do some for Solvent and Low solvent printers.
    Tony
  • Stephen Ingham
    26 January 2005 at 18:44
    tony, we have ordered some of the low solvent banner material from grafityp, should come in the morning, just in time for our new printer to be commisioned, i can try it out under the supervision of the install guy.
    I have been told by grafityp that these banners are ok for external use without lamination for 2-3 years, but we have also ordered some of the grafijuice liquid laminate, so we’ll probably try that as well.
    stephen
  • Cammy – Europoint Display
    27 January 2005 at 22:08
    What Manchester sent you was probably Orajet 3451 which is Digital Print Banner Vinyl , they should also keep 700mm wide Banner Material 440gsm i know its kept in 1370mm wide.
  • Stephen Ingham
    27 January 2005 at 22:19
    cammy, we sent it back, whatever it was, collected same day, they are good that way.
    We bought it from grafityp instead, got it this morning, just waiting for an image from a customer and then we can print our first ever banner with our new verscamm.
    stephen
  • Stuart Whitehouse
    28 January 2005 at 19:44
    Just stumbled accross this thread with interest………
    I’m going to do a promotional banner for myself. is it a big job printing on banners or is it the same as printing on vinyl?
    do you need to change anything setting wise?
    I use a cadet
    thanks
  • Stephen Ingham
    28 January 2005 at 20:14
    hiya stuart, i have only just got our versasamm and are a complete beginner to the printing game so i don’t profess to know a lot.
    However, yesterday we had a days training with a roland man, very informative.
    Today i printed 2 banners, piece of cake, excellent quality, as youd expect, you just need to ensure that the profile is set for pvc banner or to the manufacturers spec within the rip, now theres a new one on me “RIP”.
    stephen
  • Pryam Carter
    28 January 2005 at 21:36
    Check out the 550 from Hexis.
    It’s good on price and if you just alter the Generic PVC1 (i think) you get very good results. It’s a matt finish and the banner is pure white, a lot of banners have an off-white look to them that l don’t like at all. It comes in 30metres for about £70 if i’m correct. I use it on my versacamm when l get the banner work in.
  • Stephen Ingham
    28 January 2005 at 21:48
    what inks do you use?? we use eco-sol
    the banner we used came from grafityp, gloss white, low solvent stuff, excellent results.
    stephen
  • Pryam Carter
    4 February 2005 at 21:17
    Eco sol inks the same.
    The HExis banner is cheaper than the one from grafityp i think, check it out. 😉
