Home Forums Vinyl Cutter Discussions Roland Cutters Print quality on Versacamm
  • Print quality on Versacamm
    Posted by Nick Tunstill on 1 July 2013 at 14:23
    Hi I have a VS 300 and although the print quality is good, I am getting a bit of banding. I have tried changing dpi, profiles etc and have been told I can alter the V Pass or Plus Pass on the settings to smooth this out. Problem is I can’t find this setting anywhere! Running 4.1.1
    Nick
    Nick Tunstill replied 12 years, 5 months ago 5 Members · 6 Replies
  • Cheryl Smith
    2 July 2013 at 08:14
    Im no expert…not had my roland long but does yours have calibration settings ….may need to re calibrate.
  • Nick Tunstill
    2 July 2013 at 09:13
    It all seems to be calibrated ok and all nozzles clear etc. Apparently there is a setting that smooths out the print banding which is the Roland Intelligent pass control system that can be altered but I can’t find it!
  • John Dorling
    2 July 2013 at 09:30
    I think the RIPC settings are in the default media profiles. I don’t know if they can be altered elsewhere.
    Kind regards
    2 July 2013 at 15:00
    i have a vs and as long as the print test is ok then i would check the feed calibration, is this material thicker or thinner than your normal.
  • Stafford Cox
    2 July 2013 at 18:28
    quote Chris Wool:
    Agreed. Sounds like feed correction to me….
  • Nick Tunstill
    3 July 2013 at 07:34
    ok thanks will check this out
