Home Forums Printing Discussions Mimaki Printers Print Problems with CJV130
  • Print Problems with CJV130
    Posted by Andrew Fleming on 15 May 2013 at 09:51
    Can anybody help on this one, I am getting a cyan overspray/shadow on my black prints no matter what res I print at, any suggestions on how to fix.
    I emailed Hybrid 2 weeks ago about this and go read receipts from them but so far nobody has bothered coming back to me, looks like it might be time to shift to laytex HP or Roland where I know I can get an engineer, I did hear about Hybrid Ireland but cant find their details.
    Andrew Fleming replied 12 years, 5 months ago 6 Members · 20 Replies
  • 20 Replies
  • Richard Daniel
    15 May 2013 at 13:21
    quote Andrew Fleming:
    A long shot. – have you made sure that head thickness is set to thin? we had some issues with overspray. – It turned out the lever was set half way between thick and thin.
  • Andrew Fleming
    15 May 2013 at 13:30
    Yes checked that, it only happens on the black print, so if doing small letters it is a mess
    15 May 2013 at 15:26
    could be static have you been printing on to some different media of late
  • Richard Daniel
    15 May 2013 at 15:32
    Do you print on by directional and fast print? – Could try switching both of them off and a quick 5 minute nozzle wash
  • Andrew Fleming
    15 May 2013 at 15:42
    we have been printing on just the usual materials, so cant blame that, and have also tried printing 4 pass quick right upto 12 pass and on black it is still pish
  • Stafford Cox
    16 May 2013 at 10:50
    Are you using OEM or third party inks? I would try leaving on a nozzle wash for a little while (the longer the better) and then try again. Failing that, it might be new printhead time….
  • Andrew Fleming
    16 May 2013 at 11:00
    I have switched to calorific inks, but the black is still a Mimaki OEM one at present, I did a head soak for 20 mins last week to see if it helped, but no difference. Might be head time as you say…
  • Stafford Cox
    17 May 2013 at 14:41
    Given the information I can see, it does look that way. It’s strange that you have what looks like just black overspray on 2 out of 4 possible directions. If it was a calibration issue it would look very different. I would speak to whoever your maintenance company is and start the ball rolling with an engineers visit.
    Sorry, I can’t be any more help without seeing it in person.
    Stafford
  • Andrew Fleming
    19 May 2013 at 09:36
    Looks like there was an ink problem with colorific, apparently there was a bad batch of cyan which was overfilled????, they will have new carts with me Monday, so time will tell…
  • Jon Marshall
    20 May 2013 at 09:06
    Wouldn’t that rectify itself fairly quickly?
  • Stafford Cox
    20 May 2013 at 11:35
  • Andrew Fleming
    20 May 2013 at 11:50
    quote Jon Marshall:
    Time will tell, not 100% myself
  • Daniel Carey
    13 June 2013 at 10:18
    had any news on this? I am having the same issues also using colourific inks
  • Andrew Fleming
    13 June 2013 at 10:51
    Colorific are having cyan problems apparently, here is what I got from them:-
    We have identified some batch to batch issues with the cyan.
    NOT GOOD so far
  • Stafford Cox
    13 June 2013 at 12:58
    NOT GOOD so far
    I indentified a couple of these for them. It appears to only be on March and April batches as I have seen May batch numbers work fine. I believe it is 256247 (14/5/2013) onwards that are good.
    Stafford
  • Andrew Fleming
    13 June 2013 at 13:05
    The two inks I have in are both 256247 dates may, and don’t work.
  • Andrew Fleming
    13 June 2013 at 14:14
    Nice quality print.
  • Andrew Fleming
    14 June 2013 at 11:37
    OK another new batch of cyan in, time to flush and test.
  • Stafford Cox
    17 June 2013 at 12:25
    Nice quality print.
    That does look quite familioar I’m afraid. Get in touch if I can help.
    Stafford
  • Andrew Fleming
    17 June 2013 at 12:31
    New June batch and working perfectly….so far
