Home Forums Printing Discussions Roland Printers Print drying problem….
  • Print drying problem….
    Posted by Roger Clements on 22 October 2010 at 10:09
    Hi folks,
    I’m hoping someone can help with a problem I have with banner print not drying properly. I printed a banner yesterday and today while taping up (banner face down on clean smooth workbench) I noticed when it was turned right side up that the inks had scratched (scuffed) and is now unusable. I’m using the manufacturers heat profile fror the banner material and am wondering, now that the general building temperature has dropped, if I should be increasing the print/dry temps on my Sp300 and if so what would be the recommended increase?
    Any advice welcomed……thanks
    Roger Clements replied 15 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
    22 October 2010 at 13:40
    Can you feel the heat on the Roland?
    What is the temp?
  • Roger Clements
    22 October 2010 at 15:20
    Hi Dave,
    The warmth/heat can be felt and the profile for the banner material shows 37 degrees print and 40 degrees dryer.
    I have upped these to 40 print and 45 dryer and reprinted and this seems….note I said seems…… to have done the trick but help/advice from the more knowledgable would be appreciated…
  • Roger Clements
    23 October 2010 at 11:20
    Must be someone out there with some help from this huge font of knowledge?…..
    Anyone?
    23 October 2010 at 13:50
    I cook around the 40-45’s mark with the JV3, if too low the ink wont adhere to the banner very well.
  • Glenn Sharp
    23 October 2010 at 14:45
    How was the banner stored whilst out gassing Roger?
    was it hung up on a wall or laid flat on a bench. I’m just wondering if it was laid flat and the temperature of the building has dropped it might well have stayed ‘wet’
  • Jon Marshall
    23 October 2010 at 14:59
    I think thats just how it is with Eco Solvent inks.
  • Roger Clements
    24 October 2010 at 12:31
    Thanks for the replies…Glenn it was laid flat out on the work bench with the building temp around 15-20 degrees centigrade. I just tried the second banner I printed at higher temp and it’s just the same…..so I’m going for broke and cranking the temp right up and using sign & display ink profile on Versaworks…fingers crossed as this one has to be out and posted on Monday…
  • Russell Huffer
    25 October 2010 at 10:27
    I never leave anything to dry out on th e bench, always stood on end vetically. Banners i heat pre and print heaters at 35 and post at 45 and they dry almost instantly.
    Russell.
  • Roger Clements
    25 October 2010 at 13:12
    Many thanks for the replies folks…..I’m hoping having turned the temps up a fair few degrees to the mid 40’s will have done the trick.
