Home Forums Sign Making Discussions General Sign Topics Pricing on big boat graphic
  • Pricing on big boat graphic
    Posted by Paul Rollason on 1 March 2005 at 09:47
    Hi all
    We do a lot of boat names but we have been asked to do an 8m x 500mm web address down each side of a yacht in the water.
    I would be interesting to see what other people charge for such a graphic.
    Paul R(Mackerelbus design)
    johnboy replied 20 years, 9 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Broughton
    1 March 2005 at 10:29
    quote :
    in the water
    as in floating on the wet stuff not on a nice safe dry dock? the only boat I’ve done afloat was a canal boat on the sides, £400 on land, not a cat in hells chance on the water :lol1:
  • Lee Harris
    1 March 2005 at 10:43
    Morning Paul
    Hope you and Jules had a good drive home. Regarding your graphic. For that size, the minimum I would be looking at would be £590 + DANGER money.
    I hope that helps.
    Lee
  • Roy Roffey
    1 March 2005 at 11:12
    hey mate,
    we used to do the yachts in the Global Challenge yacht race and let me tell you its bloody hard graft. as a guide i would charge no less than £500 for the graphic you described if not more if its in the water. and a tip is if it looks straight – it is straight
    good luck
    roffs
  • Andrew Boyle
    1 March 2005 at 12:24
    price seems about right……….
    dangle over the side with someone sitting on you legs……..no worries
    serious comment from fiona is:
    we would charge about £500 – £550 and you should be able to do both
    sides of the yacht from the pontoon. do one section with the bow line
    eased and the stern line in tight, and then the next section. then get the
    boat turned round and do the other side. or if it is a low enough freeboard
    you could do it from the deck like andy has suggested. (ps have fitted waterline stripes to a 115 ft boat, once out the water and then when they
    changed the colour we had to make a floating dock and re-do it in the water…)
  • Andrew Boyle
    1 March 2005 at 12:34
    Hi Mackerelbus……
    Fiona the yachty one suggested I post the stripe image in the gallery…..
    done in the water … [lower ones]
  • Paul Rollason
    2 March 2005 at 14:38
    Cheers guys for all your comments
    We have just fitted the first side
    god that is a big thing to put on the side of a boat
    luckily it is only letters so top hinge and fit one letter at a time.
    Back in a minute to fit the other side
    I’ll show some pics when it’s done
    Paul R(Mackerelbus Design)
  • johnboy
    6 March 2005 at 13:38
    Paul, out of curiosity did you use “standard” vinyl? as we have done this for a few years and found “banner” vinyl to stand up to the job better! especially on “speed” boats and wet bikes.
    Johnboy 😎
