Home Forums Sign Making Discussions Job Pricing Pricing advice on directional sign
  • Pricing advice on directional sign
    Posted by Ruairi O'Boyle on 30 March 2010 at 19:01
    Guys/Girls
    Can anyone tell me where they think I am at with the pricing of these signs.
    They are metal posts with a diabond face, aluminum channels and clips to the back. It will be approx 3m tall from ground level and I reckon i will need 600mm of piping concreted into the ground.
    I was counting it at around £750 and £200 to manufacture and install. It is local to me so travel is no problem. Any comments?
    Ruairi O'Boyle replied 15 years, 9 months ago 2 Members · 3 Replies
  • Ruairi O'Boyle
    31 March 2010 at 16:09
    I am feeling left out here guys! Can anyone say aye that sounds about right or even your mad in the head!!??
  • David Rogers
    31 March 2010 at 19:56
    Not taken too much time to check the prices – but so long as you’re not screwing yourself or the customer….
    Have you planned out the time taken for digging holes & the materials you’ll use to fill the holes as if you hit hard ground…you might be a lot longer than you thought.
    If it’s local, consider putting in post liners (drainage pipe) an inch or 2 bigger than the post diameter one day then coming back 2 days later & just slotting the posts in place – no need to brace the sign as the cement sets 🙂
    Would make a comment on the proposed 600mm in the ground…
    Nursery sign – plan around 450mm and a bag of post cement per hole.
    The large one – hole should be getting on for nearer 900mm+ deep and a load of cement / postmix for good measure.
    Just consider the wind load especially if being planted in soft / open ground.
  • Ruairi O'Boyle
    31 March 2010 at 21:16
    Thanks Dave. I’ll rethink the post depth based on your suggestions.
    I think I am on the cheap side depending on fitting time but time will tell as I sent it to the customer today!
    Post liners are a good idea by the way!
