Home Forums Printing Discussions Sublimation Printing Premium T-Shirt vinyl.
  • Premium T-Shirt vinyl.
    Posted by Earl Smith on 1 September 2011 at 08:21
    Premium T-Shirt vinyl has changed or is changing to the Premium Plus version. Normal premium is being stopped, apparently. They first brought out Plus with a non sticky carrier. My opinion; dont buy this as all the small dots and detail will lift off and you cant stick them back on as there is no adhesive to stick it to.
    They are bringing out a sticky carrier version to compensate for this problem. Ask for this when you order.
    Ive just plotted and weeded for 10 t-shirts, took me over twice as long.
    Earl
    David Hammond replied 14 years, 3 months ago 7 Members · 11 Replies
  • 11 Replies
    1 September 2011 at 08:45
    Thanks Earl. I use Premium so good tip.
    Alan D
  • John Gregson
    1 September 2011 at 08:55
    Who sells the Premium T Shirt vinyl ?
    1 September 2011 at 11:19
    Target Transfers. The Premium material was/is a very good product so the Premium Plus should be very good.
    Alan D
  • Nigel Pugh
    1 September 2011 at 12:34
    Just the same as the version we call PS, so a weeding out tip for you, just put the vinyl on top of the top plate of your heat press for a few seconds to warm through then weed out, it should be a lot easier to do.
    1 September 2011 at 14:14
    I like that Nigel!
  • Nigel Pugh
    1 September 2011 at 16:08
    quote Hugh Potter:
    I like that Nigel!
    I have my moments Hugh 😀
  • Earl Smith
    1 September 2011 at 16:11
    But never more than 5 seconds or the whole lot comes off….. Done that as well.
  • Jason Middleton
    1 September 2011 at 22:19
    I believe the target transfers vinyl can be ironed over with no problems is the PS vinyl the same?
    2 September 2011 at 07:55
    Can’t comment on the PS material but the Target one definitely can be ironed over as I did some tests on it and other materials, that said it did break down after a while so I still tag my garments with do not iron directly over decoration tags. Premium was more resistant though, I’m interested in Nigel’s reply.
    Alan D
  • Nigel Pugh
    2 September 2011 at 08:25
    Yes you can iron over it but with a warm iron only, me I’m old school and still turn garments inside out to iron.
    We do sample packs of the textile films so if you want to try / test some then just give Sue Kirkwood a call.
    Nigel
    2 September 2011 at 09:08
    I use Grafityp’s PS Vinyl. I decided to carry a little stock and push the shirts a little more and seem’s to be going well.
    Not had any complaints yet, nice to work with and I rate it a lot more than Doro Tape.
    I did some testing of my own, and much to my partners annoyance I kept chucking the same shirt in the washer, and sending it around the dryer for about 2 weeks. Still stuck now.
