Home Forums Sign Making Discussions Graphic Design Help powerclip & cut help please
  • powerclip & cut help please
    Posted by Paul.Gardner on 14 April 2010 at 09:51
    I am trying to put a cut line around powerclipped object in corel x5, maybe i am doing it totally the wrong way i am not sure, if i put a outline it goes around everything and not just the clipped part, can anyone help with this ?
    Thanks Paul
    Paul.Gardner replied 15 years, 8 months ago 4 Members · 13 Replies
  • 13 Replies
  • Harry Cleary
    14 April 2010 at 10:06
    There may be an easier way…but I would do that by drawing around the flower, then place the box shape on top, ‘select all’ and click ‘back minus front’ in ‘Shaping’ on the Arrange tab.
    apologies Paul…..’front minus back’
  • Paul.Gardner
    14 April 2010 at 10:41
    Harry thanks i am getting somewhere, the only problem i have now though is it seems to outline the outside & i cannot see how to invert it, have tried moving to back of layer, have added another pic to show what am trying to do
    14 April 2010 at 10:54
    you can apply a cut path to the power clip.
    you can duplicate the power clips on top of them selfs remove the content and weld, then apply cut path.
    or have i missed the point.
    14 April 2010 at 11:01
    Is the shape vector or bitmap? I’m sure I’m understanding the question.
    Alan D
  • Paul.Gardner
    14 April 2010 at 11:05
    quote Alan Drury:
    Alan D
    shape is a vector
  • Paul.Gardner
    14 April 2010 at 11:14
    quote Chris Wool:
    I cannot see how to separate the content, maybe that is the answer, have been trying to sort this all morning 😥
    14 April 2010 at 11:17
    just for the moment i can’t see why you are using power clip on a vector ??
  • Harry Cleary
    The older and uglier experts are here Paul……I shall leave you in their capable hands! 😀
    14 April 2010 at 11:20
    less of the older 😀
  • Harry Cleary
    14 April 2010 at 11:21
  • Paul.Gardner
    14 April 2010 at 11:26
    quote Chris Wool:
    I am trying to partly cut a graphic to fit vehicle line, not sure how i should do it 😳
    14 April 2010 at 11:38
    trim these boxes out of the vehicle outline, that will leave you a separate cut path to place over the top of your printed graphic.
    one cut path will cut the shapes out the other cutpath will cut the vehicle shape.
    nice idea but are you sure the vehicle outline is accurate enough to start with.
  • Paul.Gardner
    14 April 2010 at 21:22
    Thanks for all the help, have almost got it sorted 😀
