Home Forums Printing Discussions Roland Printers Potential problem with Color camm refils
  • Potential problem with Color camm refils
    Posted by Andrew Blackett on 8 October 2002 at 17:31
    Hi all,
    a warning really, I’ve been getting my refils from Thermal Products UK since I got the machine with no problems.
    I was doing a job yesterday and today that involved the use of the spot blue (they call it “reflex blue” I believe) the problem is this:
    Once loaded it will keep snapping for no apparant reason, in the middle of the job, and potentially get jammed under the print head and cause all sorts of mischief.
    I spoke to Paul at thermal products about it, he said it may just of been a dodgy batch, and he kindly replaced the faulty ones ASAP.
    I’m not saying it will affect yours (I’ve had no problems at all with any of the refils before now) but if you do use the “reflex blue” just keep your eye on it, for the first few lines of print
    ANDY
    James White replied 22 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
    8 October 2002 at 22:01
    Was it just the one cartridge Andy or did you try more than one?
    I know dont use the Roland cartridges, how many thermal products cartridges have you used in the machine?
    I know I dont own a machine of any description but I am very interested in all aspects of the industry, and you never know one day I might be looking for a printer.
  • Andrew Blackett
    9 October 2002 at 15:53
    well, I’ve used a lot of thermal product cartridges in the machine mart’ in fact the machine has only ever 3 sets of “official” cmyk cartridges in its lifetime.
    I reloaded that ribbon into different cartridges, tried different refils too. I bought them all at once so it appears that they were part of a faulty batch.
    ANDY
  • Brian Ellis
    9 October 2002 at 18:09
    Hi Andy
    Just a thought, have you had your cam serviced or new heads. The new heads run at an increased temperature, and this causes the PE film to snap.
    Just a may be.
    Brian
  • Andrew Blackett
    9 October 2002 at 18:13
    nope 😉
    ANDY
  • WP_Graphics
    11 October 2002 at 22:53
    Andy!!
    I have had exactly the same problems with this reflex blue. I couldn’t even print one line without it snapping. I initially spoke to paul about this and he said to try a different cartridge colour ie magenta but this didn’t work either…
    Trouble is, I didn’t get my money back and I’ve got 10 refills left,.. 😥
    Do you think I should return these??
    Gav
  • Andrew Blackett
    12 October 2002 at 10:29
    Just explain that you’ve tried different cartridges and refils and had the same problem. Then ask if he’d be prepared to replace them for you
    ANDY
  • James White
    5 December 2002 at 22:33
    Hi Andy,
    We use the same supplier up to now with no problems then a magenta refill snapped re jointed it several times still snapping new refill still snapping phoned Paul who said send them back faulty batch.However problem still there with replacements another phone call to Paul advice this time drop dpi to 300, this seems to work but what when a job requires 600dpi? Any suggestions?
    James
