Home Forums Vinyl Cutter Discussions General Cutter topics plotter cutting stop start
  • plotter cutting stop start
    Posted by David Mitchell on 26 February 2016 at 07:20
    hi guys , i have a graphtec CE6000-60
    whenever i send it a large file through cutting master 3 , it runs very stop start, like cuts a small line then stops and so on.
    is this a cutter issue or a computer memory problem?
    its connected by USB with an extension.
    David Hammond replied 9 years, 10 months ago 4 Members · 4 Replies
    26 February 2016 at 11:22
    David, normally a memory/buffering problem with stuff like this, don’t use cutting master personally so don’t know if this will help but I use to get problems if the number of files in the completed job folder got to large.
    Try deleting the jobs that have been completed to see if that helps.
  • Alex Parkin
    27 February 2016 at 13:06
    Sounds like a USB problem, attach a short usb lead and see if the problem persists. My graphtec doesn’t like along usb lead.
  • David Rogers
    27 February 2016 at 17:26
    As Martin says, sounds like buffer overrun or underrun when the baud rates are too high or low / file spooler is off.
    Run through your settings. I don’t use that program so no specific info.
    27 February 2016 at 20:55
    We have the same issue with our FC8000, although it doesnt happen when using signlab.
    I’d imagine it’s a setting somewhere in CM, but I have not had time to mess about with it.
    I find keeping CM3 as the top window helps but isn’t practical.
