Home Forums Sign Making Discussions General Sign Topics Photo effect in vinyl
  • Photo effect in vinyl
    Posted by Paul Rollason on 25 August 2004 at 08:30
    Hi all
    I have recently seen an interesting effect of a photograph reproduced in strips of vinyl.
    Similar to Robs one way vinyl technique however the strips vary in thickness so when you stand back from it you see a picture. 😮
    How is this done?
    Can I do it in say corel or do I need some expensive sign software?
    Any help would be great and if you have any examples to show us that would be good too. 🙂
    Thanks a lot
    Paul R(Mackerelbus Design)
    dale s replied 21 years, 4 months ago 4 Members · 5 Replies
  • hullitec
    25 August 2004 at 08:56
    Hi Paul,
    You can do this in Signlab, not sure about Corel though.
    Mike
  • dale s
    25 August 2004 at 09:38
    Hi Paul
    I agree with mike you can do it in SignLab
    I just had a look in Corel went to trace bitmap in corel trace then used woodcut trace & got simiar effect not quite as good but you could try this & play with the settings and see what you get.
    Godd luck
    Dale
    25 August 2004 at 09:39
    hi paul, yeh, mikes right signlab has that feature. been on it for years now…
    i think some other packages can do it but the names slip me.
    ide only really advise using this method for fairly large images, as its a pain to weed the very thin parts.
  • Paul Rollason
    25 August 2004 at 10:30
    Hay Dale you are a gem 😀
    Just tried the woodcut thing and if you tweek it a bit you can get some good results
    Cheers guys off to play with my new found knowledge
  • dale s
    25 August 2004 at 10:41
    Glad I could help
    Dale
