Perspex cutting, how do you do it?
As there is a severe lack of clear perspex available I now need to use the substantial amount of off cut I have lying around.
The problem as always, is how to cut this and be left with a square, clean display edge.
I’ve used scoring blades, mini saws and hand held circular saws in the past, the result is not good enough to use and have resorted to ordering in pre-cut material which is not an option at the moment. Will presumably need some sort of table saw.
What does every one else use?
