Home Forums Printing Discussions Roland Printers Perforated cut decals, advice needed please?
  • Perforated cut decals, advice needed please?
    Posted by Chris Connor on 4 February 2019 at 00:39
    Hi all recently I have been printing and cutting a lot of individual decals approx 50mm. I have a Roland vs540i . I use AI for design and use perf cut feature which works. My question is how do I get them to fall out easier as my customers want these in 100s which takes some time to pop them all out but some are awkward and not a clean cut.
    I change the cut settings in versaworks to 200 pressure but would like to speak with anyone who maybe uses this feature a lot to see if I can perfect this? I noticed today I need a new cutting strip which I will replace this week
    Any advice would be great thanks
    Jonathan feeney replied 6 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • David Stevenson
    4 February 2019 at 08:04
    quote Chris Connor:
    You can cut them out individually simply by increasing the cut pressure until it cuts right through the media. It’s sore on blades (use cheap ebay ones for this job) and the cutting strip but by turning it upside down and sticking it in with double sided tape you get a second go with the strip. Once you get the pressure correct it works great as long as the stickers aren’t to big. Biggest problem will be picking them up from the floor and sorting them into order. We do a lot of perf cutting with approx 100g cut pressure, 250g perf, 50mm space, 2.5mm half cut, & 1g half cut pressure. Hope this helps 🙂
    4 February 2019 at 08:39
    It has been many years since we have done stickers like this. By that, I mean perforated and handed over individually.
    We do supply a lot of stickers and labels, but they are just contour cut, weeded and cut into 12-inch batches by the width of the roll which is normally 48-inch. they are then stacked, rolled-up and given to the customer to lift the stickers off themselves, as and when.
    Granted customers may request them in the fashion your providing. but in my experience for stickers, their priority is the price and perforating and cutting takes some time. And as David rightly says, the blade and cutting strip takes a battering but not forgetting, so will the head carriage mechanics on large volume work. Just make sure you are charging accordingly.
    4 February 2019 at 12:23
    We’ve one customer who can order 1000’s of these at a time.
    Bit of trial and error, but a longer cut. and short perforation. Easier to pop out, and also much quicker to cut.
  • Jonathan feeney
    4 February 2019 at 19:07
    Sorry to hijack this post but I have a customer who is looking for 2000 small keyring inserts(24x35mm) with his branding on them I have played about with different options but the cuts are rough I had tried using vinyl and cutting right through but tempted to try another material can anyone help ? im running a VP540 on versaworks using corel x7 thanks in advance
    4 February 2019 at 19:09
    I wouldn’t entertain them in a large format.
    We would run it on our Xerox and guillotine them down.
  • Jonathan feeney
    4 February 2019 at 19:14
    cheers david , its a pain the rear but its one of those ones where weve done all his signage he now wants this :rollseyes:
    4 February 2019 at 19:23
    Drop me an email or PM. It’s a doddle if it’s the type I think it is with our set up.
  • Jonathan feeney
    4 February 2019 at 19:29
    cheers david I will do
