Home › Forums › Vinyl Cutter Discussions › Graphtec Vinyl Cutters › Pens for Graphtec FC7000MK2
Posted by David Rowland on 24 November 2009 at 18:19Hey all
I got one of these courtesy of another board member…
all i need to do now is use a pen on it, we normally pen to brown paper used for locators on our old plotter.Has anyone got experience of using pens with this machnie.. i see there is water or oil based? do they dry up, whats best etc?
Been on the graphtec website and not seen them
So whats the real deal on the pens? who sells them? etc. Is there a generic plotter pen that can be used?
Is there a Graphtec representive here hidden away?
John Singh replied 16 years, 1 month ago 9 Members · 12 Replies -
hi dave
got some here but no idea where they are from
i just pop them in the holder and drop the pressure right down and go
use it for doing layouts for lettering etc
will take a pick and post it see if anyone can shed some light on its origin
if you need one as a sample pm me with your add and i can send one down to you
or if the lads want to pop up for one !
just realized these fit the cadet not sure if the same for the graphtecderek
Looking at the image you’ve posted they look very similar to my Roland Pens.
The Graphtec pen I have looks very different to the Roland. I’ll try to post a comparison later tonight.
Actually, just found my camera was in work so have posted a pic with the other one in Members Portfolio.
I collected my plotter from the Graphtec GB warehouse in Wrexham, details as follows:
Graphtec GB
Coed Aben Rd
Wrexham Ind Est
Wrexham
LL13 9UH
01978 666 700I don’t know if they’re still there but my pen came with the plotter. Yes, the water based ones (only have experience with Roland up to now) do dry up. I’ve never used oil based pens on a plotter. As for paper, I’ve normally used a really low pressure on the pen and lining paper from B&Q or Homebase.
Is this any help?
I made my own holder from the female part of a stud sign fixing. I trimmed it to suit and took the nib and ink tube out from a Bic pen and with a bit of jiggery pokery instant plotter pen. It lasts a long time in relation to those tiny felt pens, but remember to slow the plotter down to a suitable speed to match the ink deposit. Cheap as chips!
ok derek.. i send email in a mo mate
many thanks to those who have helped. Adam’s top one is the one…
So guys if they dry up then we must be buying them in the bucket load, no?
When my current pens run out, Ill be adapting the bodies to take Lumocolor pens………
got a few here if you want one dave
condition 1 is usually set up for the pen
Dave,
We’ve got a FC7000 130 mk2 machine…..The pen on this machine is excellent…..its like a little fine line pen with a lid….We simply put it in the holder take the cap of and away you go, no adjustments or anything like that.
Excellent pen works very well….
We got the machine from Signmaster systems….give phil or Richard a call im sure one of them can shed some light.
Many Thanks
Glad I could be of help to you Dave!
Chris, if you use Condition 1 for pens, do you use the same condition for cutting? I could be mistaken (no vinyl loaded right now so can’t see what condition number I’m using) but I think I use condition 1 and weight 14 for my cutting… I’ve never used the pen on this machine as I wasn’t certain what settings to use 🙂
Adam
conditions can be set for any thing just it comes out of the box as 1 for pen rest set as you like.
when pen is set in the condition then it disables the blade offsets so correct corners are produced.
pen pressure needs only to be around 8 else it damages the nibchris
Adam what machine have you got ? I have an old FC4100 and the LED display shows condition 1 to 4 so I just select which condition I want before I use the machine.
! as Chris says is set up for the pen. 2 I have set up for calendered vinyl, 3 is set up for cast material and at the moment 4 is set up for reflective. Think you can change the settings in the software but I always just use the machine menu. -
Right I see, I’ve never really played with the pressure. I’ve just replaced the blade and noticed that even though the old blade started life on pressure 14, this one is cutting a little too far into the backing for my liking, so I may reduce the weight somewhat. I’ve already adjusted the blade depth, and I can barely feel the blade when I run my finger over the holder.
I bought the machine in an emergency to get a large job done, but since then have barely had time to play with settings. There always seems to be something to do, work or otherwise!
I just stick some insulating tape around a uni ball pen
Last ages and cheap as chips
Put a little insulating tape over nib to drop drying after use
Don’t call me Mr Singh for nowt you know
