Home Forums Printing Discussions Roland Printers pc600 corel 13
  • pc600 corel 13
    Posted by N Corkhill on 25 March 2008 at 22:41
    Hi there, could anyone tell me if I am barking up the wrong tree here please 😕
    When printing on dark/ black or even clear vinyl the colours don’t show up as it needs white behind it. How do I print white first then over lay with a colour?
    Does this machine do that kind of thing 😕
    Thankyou in advance…
    BTW I am printing direct from Corel,
    N Corkhill replied 17 years, 9 months ago 7 Members · 16 Replies
  • 16 Replies
  • Ali Osman
    25 March 2008 at 23:28
    Yes you are barking up the wrong tree! – print on white vinyl, that’s what this machine is designed for
    25 March 2008 at 23:30
    not sure if you can do overprints direct from corel, and I know nowt about pc 600, but an overprint is definitely what you need to do,
    sorry not much help…
    you are not barking up the wrong tree though,
    25 March 2008 at 23:34
    Yes you are barking up the wrong tree. You need to print on a white background for the colours to show. If you need a black background you need to print this as well (all on a white vinyl to start off with).
    You can get white ribbon cartridges – but they are pretty well useless as they are far too opaque.
    If printing on clear you will need to laminate with a white background to make the colours stand out.
    Soory to be the bearer of bad news – but you can’t circumvent the laws of physics 😕
    There are machines that can do what you are describing – but the PC600 is not one of them I’m afraid.
    25 March 2008 at 23:41
    Phill,
    I always thought the pc 600 could overprint, onto white ribbon, like the gerber, only on a smaller scale?
    Long time since I first saw one demo’d but Im sure its ability to print white was a major selling point?
    25 March 2008 at 23:47
    quote Phill:
    25 March 2008 at 23:51
    quote Phill:
    quote Phill:
    Yes they do need to be opaque so as to block out the dark (or clear) substrata, is that not the point?
    A white ribbon needs to be opaque or am a barking?
  • David Rogers
    26 March 2008 at 00:00
    For Phil’s ‘opaque’ – read ‘translucent’ ? 😕
    26 March 2008 at 00:10
    Sorry Peter – Yes you are right – but I have miss understood the meaning of "opacity". 😳
    Of course I meant to say the white ribbons for the PC600 are "translucent" and not opaque. Subsequently when trying to overprint white on a black vinyl – you end up with black vinyl 😕
    At least that was my experience.
    So much so that I believe Roland stopped producing white cartridges and they can only be bought through aftermarket re-sellers.
    Thanks for pointing that out – otherwise my previous post would not have made any sense 😀
    26 March 2008 at 00:14
    Sorry Phill
    I thought the pc 600 was like the gerber,
    The word opaque was probably not clear 😀
    26 March 2008 at 00:50
    yes the white is weak but the silver and gold ribbons print beautifully on to gloss black vinyl.
    at least the edge did print white well.
  • N Corkhill
    26 March 2008 at 01:08
    Not exactly the answer I hoped for, but many thanks for your input anyway.
    Can you overprint on the silver at all?
    quote :
    Wish I knew that before, I have just bought two rolls 😥 so apart from the bin what else are they good for? are they any good providing backing when printing on clear vinyl?
    26 March 2008 at 01:15
    never overprinted the silver but a possibility.
    if you have the whites try them, corel x3 has a handy boundary creator that will be just the job for the white reverse fill.
    edge users used the silver to create a block out for double sided print printed to clear.
  • N Corkhill
    26 March 2008 at 01:29
    Hi Chris, is it possible you could explain to me how to use/ find the "boundary creator" please? and I will try out the whites and I will post the results here.
    Thankyou
    Cheers Norm
    26 March 2008 at 01:53
    third attempt at explaining its late
    create 3 shapes overlapping one another randomly select all 3.
    i think its under arrange – create boundry.
    that will create a new path as if you had welded them all together.
    but handles more complex designs easy-er than breaking apart etc and welding.
    you need this shape to assign the white too
    26 March 2008 at 08:15
    You can set Corel to overprint but I’m not sure if it works with your machine as the feature is designed for litho work, Select your object, right click and select overprint fill or overprint outline if there is one.
    Alan D
  • N Corkhill
    26 March 2008 at 09:19
    Thanks guys, will have a go at and post the results. 😀
