Activity Feed › Forums › Sign Making Discussions › File Swapping › Papyrus type font required
Posted by John Harding on August 3, 2009 at 3:28 pmas the title suggests i need a font similar in overall shape to papyrus but without all the little jaggedy bits.
any suggestions on a close match withh smooth lines?
thanks for looking – John 😀
John Harding replied 14 years, 9 months ago 4 Members · 8 Replies -
There is a similar font to that but it is all caps, you want it?
Goblin Hand by the way.If you get stuck Peter Normington had this a few weeks ago and I believe he used papyrus but smoothed the edges out somehow in Signlab
thanks Chris – I will probably need lowercase hopefully Peter might see this or anyone else with a close font match please
cheers – John
if you put an inline onto the font, and then outline it the original amount with rounded corners it will remove the silly bits on it, if that makes sense
I had a job to find anything close, only as mentioned by Chris, only in upper case, so I ended up tidying up Papyrus, only a few words though and several repeat letters, so not to time consuming.
Cant help really
quote :I had a job to find anything close, only as mentioned by Chris, only in upper case, so I ended up tidying up Papyrus, only a few words though and several repeat letters, so not to time consuming.
Cant help really
im being cheeky so not offended if you say no Peter but what letters have you done, I need two words ‘Saffron Cafe’ an of course I have the two caps already 😀
I can only match the e o & r in lower case
but you are welcome to them if it saves you a bit of timePeter
