Panelling graphics ready for part vehicle wrap
Morning all
I mainly do cut vinyl lettering on vehicles so I’ve not really nailed down the process of doing wraps / part wraps and tiling them ready for print.
Just wondering how you set it up ready for print?
I have attached a break down of what I tend to do, I may of missed a couple of steps as I was trying to do it fast so you had something visual rather than me just describing it.
Measuring / Using Impact outlines
I take it 99% of you use the impact library but..- Do you physically measure the vehicle?
- If so, what parts do you make sure you measure?
Bleed
- I suppose this depends on if you measure the vehicle or just use the template.
- How do you accommodate the parts that curve round the panels, i.e. where the rear doors meet the sides or when the sides meet the roof?
- What bleed do you use between the doors so you can lose the join line in the door gap?
- What bleed do you use when you simple need to tile graphics together on a single panel (no door gaps)
- Contour cutting is not 100% so you have to give the graphics a bleed to compensate for this, what bleed do you use and does it depend on the length of the graphics, i.e. is 5mm bleed enough when printing 3-5 metres
Gaps between graphics
On my design, the main part is green but I have the grey part that runs along the same line, obviously it would be easier to print these in the correct place so when it comes to fitting they’re already lined up, on cut lettering we would simple use application tape to hold them together but would you still use application tape or would you fit them separately when doing a part wrap? Or would you even leave the white in the middle and have the green and grey parts connected?Printing solid colours
From my little knowledge of printing, I understand when printing solid colours, you need to print them in the same direction.I don’t have great experience printing solid colours but they may have been down to the third party inks I was using, I’ve now got rid of the Atlantic inks but would my tiling be ok so print a consistent colour?I may have my setup completely wrong so how would you do it?
Dan
