Home Forums Sign Making Discussions General Sign Topics palight alternatives???
  • palight alternatives???
    Posted by paddy on 14 May 2003 at 20:56
    Got a job to do for a local company who want signs makign to hang off scaffolding at their jobsites.
    They wont entertain banners.
    What they require is Red lettering on a yellow background. I have quoted for Palight 5mm board from Cherwell but am wondering if there is a cheaper alternative.
    The signs are to be 2off 1200mm x 900mm boards and I dont really want to go into the realms of laminating white foamex.
    I believe I have quoted to cheaply for these items and need to make a bit more profit using cheaper materials.
    Lorraine Buchan replied 22 years, 7 months ago 3 Members · 3 Replies
    14 May 2003 at 23:07
    Why not just use yellow foamex if you don’t want to floodcoat white Paddy ?
    Why do they not want banners, a lot of builders use banners with pole pockets top and bottom for the poles to slide through. They would last much better than foam which is a bit fragile and is liable to break easily.
  • Lee Attewell
    15 May 2003 at 00:12
    Hey Paddy, How “cheap” would it be if the customer had to constantly replace damaged signs? Go the banner mate.
  • Lorraine Buchan
    16 May 2003 at 09:06
    How about using Correx Paddy, you can get it in 10mm thick.
    As the others say try explaining your customer that something like pailight/forex etc will damage easy and they will need replacing far sooner than a banner would.
