Home Forums Sign Making Discussions Neon, LED, Lighting Painted foamex lettering durability
  • Painted foamex lettering durability
    Posted by Myles Brewer on 24 February 2010 at 21:43
    Hi all,
    What would be a reasonable expectation of the durability of gloss painted 19mm foamex lettering fitted to a shop front?
    I have a customer asking & not sure what to tell them.
    I have fitted lettering which has been up for 2-3 years & still looks as good as new, but having just looked on a few sign makers websites, & noticed generally they seem to only give an expected outdoor durability of about 12 months.
    Surely as Foamex is a relatively waterproof material & if then given a good spraying with gloss paint I would think it could possibly last 6, 8, maybe even 10 years.
    Has anyone done any lettering like this that’s still looking good after that sort of time span?
    Myles
    Gwaredd Steele replied 15 years, 9 months ago 5 Members · 6 Replies
  • Harry Cleary
    24 February 2010 at 21:52
    As long as the prep is done right (key the bejayus out of it 😀 I use scotch pads that you get in motor factors.) and you use u/c and a couple of top coats it will last as long as paint on timber Myles,
    I have painted full sheets and letters and never had probs. Allow plenty of time for it to properly cure before installing though.
    hope that helps.
    24 February 2010 at 21:58
    I have had 10mm vinyl faced cut out letters on a unit I did 10 years ago,
    still good,
  • Myles Brewer
    24 February 2010 at 22:00
    Thanks Harry,
    I actually outsource them from Cutting Edge usually & they always do a cracking job of them, so I reckon they’d be good for a good few years.
  • Myles Brewer
    24 February 2010 at 22:02
    quote Peter Normington:
    still good,
    Excellent Peter, That’s exactly what I wanted to hear 😀
  • Richard Urquhart
    25 February 2010 at 09:50
    Just finished a load of these, bit of a pain but as follows, first clean with IPA, then key with red scotch pads, plastic prime and 2k primer to seal the edges and then 2k base coat followed by 2k clear coat.
    Rich
  • Gwaredd Steele
    25 February 2010 at 10:17
    HMG do a primerless paint designed for foamex. Just key & go. Comes in all RAL colours etc. A year or so on, & it still looks fine.
