Home › Forums › Printing Discussions › Screen Printing › Over 1.5mtr Screen Printing – is this possible?
Posted by Ian Higgins on 6 April 2005 at 10:50Hi Folks,
I have been given a job to price up for screen printing. put it on here for quotes but o replies..
Someone has told me that a 1.5mtr screen is too large!
Is this true or does anyone on here have screens that big?Cheers
IanMike Smith replied 19 years, 8 months ago 9 Members · 12 Replies -
hi 😀
you can get screens that big, it depends on your printing table and what size it could hold. i have one at 82″x56″ but then again if it was 1.5meter square i think you would struggle to get anything suitable 😛
Nik
There are a few companies that can screen print a continuos length.
edit-admin
The reason is mainly cost, Screen printing will be a lot cheaper I am sure.
Having said that I have not had much joy printing on clear.
Ian -
quote :Having said that I have not had much joy printing on clear.
do you find that the colours “bleed” Ian, as i do with my Rockhopper.
I would have thought you full solvent would have been OK on clear!!
L J -
HI LJ…
No it was not the bleed that was the problem.. it just looked a bit wishy washy!!
only tried it once so could probably do it better now with a bit more knowledge
Ian -
yes i forgot about that part (wishy washy) so i tried a higher dpi but that was then causing the bleeding.
the only way i cured the faded look was to put a panel of white vinyl over the back (on inside of window printed in reverse of course). so i try to stay away from clear vinyl printing now.
L J) -
assuming you need a reasonable quantity in 1500 x 190 then most reasonable size screen printers will print 5 up on a 1040 x 1550 press, there are a few in Yorkshire that would do that no problem.
i think 1.5mtr is Brushwood Design’s screen limit in North Devon or it becomes just very difficult. They are street-banner printers.
Hi I realise I’m a bit late with this post but the company I used to work for could print/floodcoat up to 2.9m long.
Don’t know if this helps anyone… -
How many colours is the design?
Have you thought of cutting the design out of transfer film and heat pressing it on?
