Ouch!! one of those weeks
Everytime I seem to be making headway, something crops up.
Just before I went in to hospital, my second machine went nuts, and stopped printing anywhere near decent. I couldn’t use it for any close work at all.. I had no missing pins, but the overspray on two colours was awful. Both machines were a month off their 6 monthly service, so I rang the techs and asked them to do the services early, and replace one of the heads.
They came out and while they were replacing the head, one of the pumps seized and needed replacing. Then the waste line became blocked and needed unblocking. It couldn’t be unblocked properly, so they replaced the tubing back to the caps. Then they noticed the caps had not been replaced on the last service, so they insisted on replacing all of them. When they had finished, after a fair few hours, the bill was over $3000 😮 ($250 call out and $170 an hour plus parts)
That was bad enough. Then, I went into hospital and was off work for 2 weeks. The day I got back, I turned my other machine on and it came up with a ‘sum error’ and showed it was a ‘jetpro 2’ on the lcd screen. What the?
I rang tech support and they told me the battery backup had probably died. It would be a 2 hr fix. They’d have to change the battery then reload the data back into the motherboard.
It was no good to me as it was, so asked them to get it working.
The tech came out, replaced the battery, even though he didn’t think it needed it, then spent over 2 hours reloading the data. That meant also redoing the service of the heads and calibration of the print and cut etc.
That cost me close to $500 😮
The tech had no sooner driven off, and I got the ‘sum error’ again.
I rang the tech company and they got the guy to come back before he left the area.
After several more hours, he decided the motherboard needed replacing. What! How much is that I asked.
Probably close to $2000 he reckoned. They only had one in stock, and if I wanted to proceed, he’d have to advise his office to hold it for me.
Once again, it was no good to me not working, and my workload was building up, so I approved him to replace the board.
He needed to get the senior technician from head office to make sure his diagnosis was right, so he was called to come and have a look.
Problem was, the data was now corrupt, so he had to log onto a database somewhere and re download virgin data, then update the version, then re calibrate it, and re test it. Then, they realised that the new board was working so well, it seemed to make my print heads work ‘better’ and caused the oldest 4 to start overspraying wildly. I had to replace 2 of them as it was hopeless. I used the last 2 heads in stock. I am trying to work with the other two heads until I can afford to change them.
When the tech left, he gave me a bill for just under $7000. I nearly died.
The motherboard was charged at $3300 – not $2000. He apologised for the misquote, but he would look after me on the heads.
In two bills I’ve been charge over $10,000!!! Not for the faint hearted.
That, combined with not working for 2 weeks, and on light duties for another two weeks, I’ve had better months 🙁
Roland may not make huge profits on their machines, but they make up for it on the spares. Nothing short of a rip off in my opinion. It is such a closed shop for repairs, we are all held to ransom when things fail.
Rant over….. 🙄
