Home Forums Printing Discussions Roland Printers Ongoing problem with work being smudged, advice please?
  • Ongoing problem with work being smudged, advice please?
    Posted by Barry Williams on 11 February 2018 at 20:49
    Greetings all-
    I have an on-going problem with my Roland sp300V in that it sometimes smudges
    and destroys the image.
    It appears as if the carriage is striking the vinyl. The heaters are working ok across the bed and vacuum is set at 100%. It was suggested that the work environment may be too cool but as the machine is in a 12’x12′ room in my home it is quite cosy.
    It is (unfortunately) not a busy machine.
    Any suggestions would be welcome.
    Regards,
    Barry
    Barry Williams replied 7 years, 6 months ago 6 Members · 12 Replies
  • 12 Replies
  • Stafford Cox
    11 February 2018 at 21:00
    Can you post any pictures of the problem? It might be easier to diagnose if we can see the results.
  • Barry Williams
    11 February 2018 at 21:13
    Thanks for the reply and I will try to attach pics of damaged work
    when next printing.
    regards,
    Barry
  • Jon Marshall
    12 February 2018 at 11:24
    Try turning the pre/print heaters down for the material you are working with..
  • Barry Williams
    12 February 2018 at 12:45
    Example of the smudged print.
    Barry
    12 February 2018 at 14:14
    It looks like your vinyl is puckering slightly in the machine (i.e not lying perfectly flat) so the print head is brushing against the raised sections. Overnight temp. changes and or damp conditions can cause this but the solution is to ensure your vinyl is staying perfectly flat in the machine during printing.
  • Barry Williams
    12 February 2018 at 14:30
    Thanks for the hints Phil,
    Barry
  • David Stevenson
    12 February 2018 at 15:09
    Definitely head strikes as Phill said. We have to advance our material approx 1m in the morning if its been in the machine overnight. If you look at your head you’ll most likely find it is all small scratches running from left to right 🙁
  • Denise Goodfellow
    13 February 2018 at 18:13
    Always have your take up roller attached, pulling your vinyl tight
  • Barry Williams
    16 February 2018 at 09:37
    Thanks to all for your hints.
    I don’t have a take-up on the machine but it has been suggested that
    I weight the outputted end to create tension.
    I will try leaving a mtr or so fed out overnight also.
    Regards,
    Barry
  • Barry Williams
    8 June 2018 at 16:04
    Again many thanks to all for the hints re solving the smudging problem.
    I guess that the recent very warm weather has indicated a heat issue here in my little signshop.
    Yesterday I completed a full day’s printing without a smudge.
    The temp. in the signshop was 70+ which left the print media very soft and flexible and thereby allowed it to lie really flat on the printer bed.
    Result–no smudges.
    Yes–a temperature issue.
    Regards,
    Barry
  • David Stevenson
    8 June 2018 at 16:14
    Sorry Barry, when I mentioned feeding out a metre of material that would be before printing in the morning. Essentially what you’d be doing is feeding any material that’s been exposed to the air away from your print heads. You’ll normally notice in the morning slight wrinkles in your material. If it’s fresh off the roll you don’t get this. Hope this makes sense, I can hardly understand myself sometimes lol
  • Barry Williams
    8 June 2018 at 16:32
    Many thanks David for the clarification.
    Regards,
    Barry
